주요 콘텐츠로 건너뛰기
LG G3 Loudspeaker Replacement
필요한 것
  1. LG G3 Loudspeaker Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 LG G3 Loudspeaker Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Loudspeaker Replacement: 2 단계, 이미지 2개 중 1개 LG G3 Loudspeaker Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Loudspeaker Replacement, Battery: 3 단계, 이미지 2개 중 1개 LG G3 Loudspeaker Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Loudspeaker Replacement: 4 단계, 이미지 2개 중 1개 LG G3 Loudspeaker Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the battery out of its recess and remove it.
  5. LG G3 Loudspeaker Replacement, Loudspeaker: 5 단계, 이미지 1개 중 1개
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Loudspeaker Replacement: 6 단계, 이미지 2개 중 1개 LG G3 Loudspeaker Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Loudspeaker Replacement: 7 단계, 이미지 3개 중 1개 LG G3 Loudspeaker Replacement: 7 단계, 이미지 3개 중 2개 LG G3 Loudspeaker Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
246,745 평판
안내서 682개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 14,488
