이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
Pry the back cover up to separate its plastic clips.
Lift the back cover to release the rest of the plastic clips and remove it.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
Work your way along the right edge.
Carefully lift the right edge of the motherboard cover.
Remove the motherboard assembly.
