주요 콘텐츠로 건너뛰기
LG G3 Motherboard Replacement
필요한 것
  1. LG G3 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Motherboard Replacement, Battery: 3 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the battery out of its recess and remove it.
  5. LG G3 Motherboard Replacement, Loudspeaker: 5 단계, 이미지 1개 중 1개
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 LG G3 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 LG G3 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Motherboard Replacement, Motherboard Cover Assembly: 8 단계, 이미지 1개 중 1개
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 LG G3 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 LG G3 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 LG G3 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 LG G3 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Motherboard Replacement, Motherboard: 11 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement, Motherboard: 11 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the display flex cable.
  12. LG G3 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the digitizer flex cable.
  13. LG G3 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  14. LG G3 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the front camera flex cable.
  15. LG G3 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
  16. LG G3 Motherboard Replacement: 16 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement: 16 단계, 이미지 2개 중 2개
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
  17. LG G3 Motherboard Replacement: 17 단계, 이미지 2개 중 1개 LG G3 Motherboard Replacement: 17 단계, 이미지 2개 중 2개
    • Grab the top section of the motherboard and carefully lift it out of the phone.
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
246,775 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,626개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 40
전체 시간: 3,809
