주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G3 Power & Volume Button Cable Replacement
필요한 것
  1. LG G3 Power & Volume Button Cable Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 LG G3 Power & Volume Button Cable Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
    댓글 쓰기
  2. LG G3 Power & Volume Button Cable Replacement: 2 단계, 이미지 2개 중 1개 LG G3 Power & Volume Button Cable Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    댓글 쓰기
  3. LG G3 Power & Volume Button Cable Replacement, Battery: 3 단계, 이미지 2개 중 1개 LG G3 Power & Volume Button Cable Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    댓글 쓰기
  4. LG G3 Power & Volume Button Cable Replacement: 4 단계, 이미지 2개 중 1개 LG G3 Power & Volume Button Cable Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the battery out of its recess and remove it.
    댓글 쓰기
  5. LG G3 Power & Volume Button Cable Replacement, Loudspeaker: 5 단계, 이미지 1개 중 1개
    • Remove the four Phillips #00 screws (4 mm length).
    댓글 쓰기
  6. LG G3 Power & Volume Button Cable Replacement: 6 단계, 이미지 2개 중 1개 LG G3 Power & Volume Button Cable Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
    댓글 쓰기
  7. LG G3 Power & Volume Button Cable Replacement: 7 단계, 이미지 3개 중 1개 LG G3 Power & Volume Button Cable Replacement: 7 단계, 이미지 3개 중 2개 LG G3 Power & Volume Button Cable Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
    댓글 쓰기
  8. LG G3 Power & Volume Button Cable Replacement, Motherboard Cover Assembly: 8 단계, 이미지 1개 중 1개
    • Remove the eight Phillips #00 screws (4 mm length).
    댓글 쓰기
  9. LG G3 Power & Volume Button Cable Replacement: 9 단계, 이미지 3개 중 1개 LG G3 Power & Volume Button Cable Replacement: 9 단계, 이미지 3개 중 2개 LG G3 Power & Volume Button Cable Replacement: 9 단계, 이미지 3개 중 3개
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
    댓글 쓰기
  10. LG G3 Power & Volume Button Cable Replacement: 10 단계, 이미지 3개 중 1개 LG G3 Power & Volume Button Cable Replacement: 10 단계, 이미지 3개 중 2개 LG G3 Power & Volume Button Cable Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
    댓글 쓰기
  11. LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: 11 단계, 이미지 2개 중 1개 LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: 11 단계, 이미지 2개 중 2개
    • Remove the last screw attaching the rear camera lens to the frame.
    • Now use a plastic spudger to carefully remove the camera lens.
    댓글 쓰기
  12. LG G3 Power & Volume Button Cable Replacement: 12 단계, 이미지 3개 중 1개 LG G3 Power & Volume Button Cable Replacement: 12 단계, 이미지 3개 중 2개 LG G3 Power & Volume Button Cable Replacement: 12 단계, 이미지 3개 중 3개
    • Using the spudger, release power & volume button flex from adhesive carefully.
    댓글 쓰기
  13. LG G3 Power & Volume Button Cable Replacement: 13 단계, 이미지 1개 중 1개
    • Finally, remove the flex.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sophia
회원 가입일: 03/25/14
43,911 평판
안내서 62개를 작성함
1가이드 댓글
I bought a more powerful battery. 6800 mah .instead of the 3000mah OEM . Ia there any problem using it?
mitoll - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 40
전체 시간: 22,695
