주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G5 Camera Sensor Replacement
필요한 것
  1. LG G5 Camera Sensor Replacement, Front Panel Assembly: 1 단계, 이미지 2개 중 1개 LG G5 Camera Sensor Replacement, Front Panel Assembly: 1 단계, 이미지 2개 중 2개
    • While holding the battery release button, pull the bottom end of the phone out of the body.
    댓글 쓰기
  2. LG G5 Camera Sensor Replacement: 2 단계, 이미지 3개 중 1개 LG G5 Camera Sensor Replacement: 2 단계, 이미지 3개 중 2개 LG G5 Camera Sensor Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
    댓글 쓰기
  3. LG G5 Camera Sensor Replacement: 3 단계, 이미지 2개 중 1개 LG G5 Camera Sensor Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
    댓글 쓰기
  4. LG G5 Camera Sensor Replacement: 4 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
    댓글 쓰기
  5. LG G5 Camera Sensor Replacement: 5 단계, 이미지 2개 중 1개 LG G5 Camera Sensor Replacement: 5 단계, 이미지 2개 중 2개
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
    댓글 쓰기
  6. LG G5 Camera Sensor Replacement: 6 단계, 이미지 2개 중 1개 LG G5 Camera Sensor Replacement: 6 단계, 이미지 2개 중 2개
    • Peel the screen away from the body. The two parts should be completely separated.
    댓글 쓰기
  7. LG G5 Camera Sensor Replacement, Screen: 7 단계, 이미지 2개 중 1개 LG G5 Camera Sensor Replacement, Screen: 7 단계, 이미지 2개 중 2개
    • Once the screen has been separated from the back of the phone, now you can remove the motherboard.
    • Using the #00 Philips head, remove the six 2.7mm Phillips screws.
    댓글 쓰기
  8. LG G5 Camera Sensor Replacement: 8 단계, 이미지 2개 중 1개 LG G5 Camera Sensor Replacement: 8 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool between the screen-ribbon-connector and the motherboard, then pull up. It should pop out easily.
    댓글 쓰기
  9. LG G5 Camera Sensor Replacement: 9 단계, 이미지 1개 중 1개
    • Separate the motherboard of the phone from the screen of the phone
    댓글 쓰기
  10. LG G5 Camera Sensor Replacement: 10 단계, 이미지 2개 중 1개 LG G5 Camera Sensor Replacement: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Make sure to transfer the earpiece from the old screen to the new screen or else you wouldn't be able to hear anyone when you make phone calls!
    • The component is fragile so don't try to force it to come out with a pair of tweezers. A pick should be able to wedge it out.
    • Be careful with the adhesive that's connected to it. It's easy to pull out.
    댓글 쓰기
  11. LG G5 Camera Sensor Replacement: 11 단계, 이미지 1개 중 1개
    • Also remove the earpiece casing from the old screen by popping it out with a pair of tweezers.
    • On the new screen, place the casing down first and making sure that it's locked in place. Then place the earpiece on top of it. Gently push it down with your finger until it's secure.
    댓글 쓰기
  12. LG G5 Camera Sensor Replacement, Camera Sensor: 12 단계, 이미지 3개 중 1개 LG G5 Camera Sensor Replacement, Camera Sensor: 12 단계, 이미지 3개 중 2개 LG G5 Camera Sensor Replacement, Camera Sensor: 12 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, remove the ribbon attaching the sensor to the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Parker Reynolds
회원 가입일: 10/03/16
937 평판
안내서 2개를 작성함
Cal Poly, Team 18-2, Forte Fall 2016 Cal Poly, Team 18-2, Forte Fall 2016 회원
CPSU-FORTE-F16S18G2
4 회원들
안내서 21개를 작성함
1가이드 댓글
Is that the camera sensor that has been removed or the wide angle camera?
Thomas Charnley - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 43
전체 시간: 5,223
