주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G6 Motherboard Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. LG G6 Motherboard Replacement, iOpener Heating: 1 단계, 이미지 2개 중 1개 LG G6 Motherboard Replacement, iOpener Heating: 1 단계, 이미지 2개 중 2개
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    댓글 쓰기
  2. LG G6 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    댓글 쓰기
  3. LG G6 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    댓글 쓰기
  4. LG G6 Motherboard Replacement, Alternate iOpener heating method: 4 단계, 이미지 2개 중 1개 LG G6 Motherboard Replacement, Alternate iOpener heating method: 4 단계, 이미지 2개 중 2개
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    댓글 쓰기
  5. LG G6 Motherboard Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Apply the heated iOpener to the edge of the phone for about 2 minutes.
    댓글 쓰기
  6. LG G6 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 LG G6 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 LG G6 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
    • Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
    • Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
    댓글 쓰기
  7. LG G6 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 LG G6 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Using a Philips 000 bit, remove 11 screws from the highlighted locations.
    댓글 쓰기
  8. LG G6 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 LG G6 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • With the screws removed, remove the lower frame components, followed by the upper mid-frame. Both components can be removed with a little prying.
    댓글 쓰기
  9. LG G6 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Begin battery removal by very gently prying off the power ribbon with a plastic card or a nylon spudger.
    댓글 쓰기
  10. LG G6 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 LG G6 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 LG G6 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive.
    • Do not use a knife as you may pierce the battery.
    댓글 쓰기
  11. LG G6 Motherboard Replacement, Motherboard: 11 단계, 이미지 2개 중 1개 LG G6 Motherboard Replacement, Motherboard: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the sim card tray release mechanism on the right edge.
    • Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
    댓글 쓰기
  12. LG G6 Motherboard Replacement: 12 단계, 이미지 3개 중 1개 LG G6 Motherboard Replacement: 12 단계, 이미지 3개 중 2개 LG G6 Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Gently pry off the two connectors at the bottom of the phone.
    • Pry off the tape covering the vibrator.
    댓글 쓰기
  13. LG G6 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 LG G6 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • The motherboard is now removable by gently lifting.
    • Upon removal of the motherboard, the small plastic sim card tray release mechanism will be loose and may get lost.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
David Pugliese
회원 가입일: 09/26/17
1,156 평판
안내서 4개를 작성함
USF Tampa, Team S2-G6, Passmore Fall 2017 USF Tampa, Team S2-G6, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G6
4 회원들
안내서 21개를 작성함
4가이드 댓글
Hi where i can find mainborad for lg g6 h870
Zaid Nashwan - 답글 공유
i found one on ebay
Greg - 답글 공유
How much access to the SIM Reader does this give you? A customer has broken his SIM Tray and there is a part stuck inside, will removing the board allow me to reach this or would I be removing it for no reason?
Any response appreciated, ty.
RDCharlton - 답글 공유
very good detail
Greg - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 40
전체 시간: 8,090
