주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Incite Back Panel Replacement
필요한 것
  1. LG Incite Back Panel Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Hold the phone camera-side up and locate the rear cover.
    댓글 쓰기
  2. LG Incite Back Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
    댓글 쓰기
  3. LG Incite Back Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
    댓글 쓰기
  4. LG Incite Back Panel Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
    댓글 쓰기
  5. LG Incite Back Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
    댓글 쓰기
  6. LG Incite Back Panel Replacement: 6 단계, 이미지 1개 중 1개
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
10다른 기여자 명과 함께
Kimberly Kha
회원 가입일: 04/16/13
163 평판
안내서 5개를 작성함
Cal Poly, Team 2-18, Maness Spring 2013 Cal Poly, Team 2-18, Maness Spring 2013 회원
CPSU-MANESS-S13S2G18
4 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 30
전체 시간: 1,017
