주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Incite Touch Screen Replacement
필요한 것
    1. LG Incite Touch Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Hold the phone camera-side up and locate the rear cover.
      댓글 쓰기
    2. LG Incite Touch Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
      댓글 쓰기
    3. LG Incite Touch Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Place the plastic opening tool in the small slot below and to the left of the battery.
      • Pry the battery upward to remove it.
      댓글 쓰기
    1. LG Incite Touch Screen Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
      • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
      댓글 쓰기
    2. LG Incite Touch Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
      • Gently move the tool around the perimeter of the screen to separate it from the body.
      • You should not completely separate the screen from the device in this step.
      댓글 쓰기
    3. LG Incite Touch Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Flip the device over so the battery compartment faces up.
      • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
      • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
      • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
      댓글 쓰기
    1. LG Incite Touch Screen Replacement, Motherboard: 7 단계, 이미지 3개 중 1개 LG Incite Touch Screen Replacement, Motherboard: 7 단계, 이미지 3개 중 2개 LG Incite Touch Screen Replacement, Motherboard: 7 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
      • Do not completely remove the tab from the body, it should still be connected to the phone by the orange plastic.
      • Repeat this for the white tab on the opposite side of the phone.
      • This tab also has two plastic bases adhering it to the edge of the phone.
      댓글 쓰기
    2. LG Incite Touch Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Insert your plastic opening tool underneath the speaker/camera panel, and gently pry it upwards.
      • Do not fully remove the panel! It should still be attached to the motherboard by a red and black wire.
      댓글 쓰기
    3. LG Incite Touch Screen Replacement: 9 단계, 이미지 2개 중 1개 LG Incite Touch Screen Replacement: 9 단계, 이미지 2개 중 2개
      • Use the metal tweezers to gently lift the edge of the maroon tab, it should pop up easily.
      • Do not remove the tab completely, it should still be connected to the phone.
      댓글 쓰기
    4. LG Incite Touch Screen Replacement: 10 단계, 이미지 1개 중 1개
      • Insert the plastic opening tool underneath the motherboard towards the bottom edge of the phone and gently pry it from its case.
      • Lift the motherboard and slide it towards you by hand to free it from the phone.
      • The call and end buttons may fall out when the motherboard is removed! Don't lose the buttons.
      댓글 쓰기
    1. LG Incite Touch Screen Replacement, Touch Screen: 11 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Remove the call and end buttons using the metal tweezers.
      댓글 쓰기
    2. LG Incite Touch Screen Replacement: 12 단계, 이미지 1개 중 1개
      • Wedge the plastic opening tool between the screen and sides of the phone.
      • Slide the tool along the edge to loosen the screen.
      • Repeat for the opposite side.
      • Don't completely remove the screen yet to avoid damaging the screen.
      댓글 쓰기
    3. LG Incite Touch Screen Replacement: 13 단계, 이미지 1개 중 1개
      • Wedge the plastic opening tool under the screen where the buttons were to loosen it.
      댓글 쓰기
    4. LG Incite Touch Screen Replacement: 14 단계, 이미지 2개 중 1개 LG Incite Touch Screen Replacement: 14 단계, 이미지 2개 중 2개
      • Gently peel the touch screen off from the bottom of the phone.
      • Do not damage the yellow tab in the upper right corner of the phone.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kimberly Kha
회원 가입일: 04/16/13
163 평판
안내서 5개를 작성함
Cal Poly, Team 2-18, Maness Spring 2013 Cal Poly, Team 2-18, Maness Spring 2013 회원
CPSU-MANESS-S13S2G18
4 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 22
전체 시간: 1,588
