주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Intuition Power Button Replacement
필요한 것
  1. LG Intuition Power Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the device so the two bottom screws are shown.
    댓글 쓰기
  2. LG Intuition Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
    댓글 쓰기
  3. LG Intuition Power Button Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
    댓글 쓰기
  4. LG Intuition Power Button Replacement: 4 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
    댓글 쓰기
  5. LG Intuition Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
    댓글 쓰기
  6. LG Intuition Power Button Replacement: 6 단계, 이미지 2개 중 1개 LG Intuition Power Button Replacement: 6 단계, 이미지 2개 중 2개
    • Gently raise the battery from its compartment.
    댓글 쓰기
  7. LG Intuition Power Button Replacement, Plastic Motherboard Shield: 7 단계, 이미지 1개 중 1개
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
    댓글 쓰기
  8. LG Intuition Power Button Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
    댓글 쓰기
  9. LG Intuition Power Button Replacement, Camera: 9 단계, 이미지 1개 중 1개
    • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
    댓글 쓰기
  10. LG Intuition Power Button Replacement: 10 단계, 이미지 1개 중 1개
    • Using the ribbon beneath the camera lift it upwards and pull the camera out.
    댓글 쓰기
  11. LG Intuition Power Button Replacement, Volume Buttons: 11 단계, 이미지 2개 중 1개 LG Intuition Power Button Replacement, Volume Buttons: 11 단계, 이미지 2개 중 2개
    • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
    댓글 쓰기
  12. LG Intuition Power Button Replacement, Screen Protector: 12 단계, 이미지 2개 중 1개 LG Intuition Power Button Replacement, Screen Protector: 12 단계, 이미지 2개 중 2개
    • Carefully use the plastic opening tool to pry the ribbon cable below the volume buttons on the left side of the phone.
    • Carefully use the plastic opening tool to pry the ribbon cable to the left of the camera.
    댓글 쓰기
  13. LG Intuition Power Button Replacement: 13 단계, 이미지 2개 중 1개 LG Intuition Power Button Replacement: 13 단계, 이미지 2개 중 2개
    • Carefully use the plastic opening tool to pry the wire that connects to the bottom home and back display buttons.
    • Carefully use the plastic opening tool to pry the second wire on the right side of the battery that also connects to the bottom home and back display buttons.
    댓글 쓰기
  14. LG Intuition Power Button Replacement: 14 단계, 이미지 1개 중 1개
    • Carefully use the plastic opening tool to pry the motherboard from the front screen.
    댓글 쓰기
  15. LG Intuition Power Button Replacement: 15 단계, 이미지 2개 중 1개 LG Intuition Power Button Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the 5mm Phillips #00 screw below the volume buttons holding the plastic shield onto the screen display.
    • Remove the 5mm Phillips #00 screw on the top right of the phone.
    댓글 쓰기
  16. LG Intuition Power Button Replacement: 16 단계, 이미지 1개 중 1개
    • Carefully pull the ribbon cable upward and away from the front screen display.
    댓글 쓰기
  17. LG Intuition Power Button Replacement: 17 단계, 이미지 1개 중 1개
    • Carefully use the plastic opening tool to pry the screen protector from the display and motherboard.
    댓글 쓰기
  18. LG Intuition Power Button Replacement: 18 단계, 이미지 2개 중 1개 LG Intuition Power Button Replacement: 18 단계, 이미지 2개 중 2개
    • Slowly separate the front screen from the screen protector. This will remove the screen protector from the phone.
    댓글 쓰기
  19. LG Intuition Power Button Replacement, Power Button: 19 단계, 이미지 1개 중 1개
    • Slowly separate the power button from the screen display. This will release the power button.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Thomas Morrissey
회원 가입일: 10/25/18
616 평판
안내서 6개를 작성함
UMass Dartmouth, Team S3-G4, Peak Fall 2018 UMass Dartmouth, Team S3-G4, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G4
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 21
전체 시간: 703
