주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG K30 Rear Facing Camera Replacement
필요한 것
  1. LG K30 Rear Facing Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG K30 Rear Facing Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
    댓글 쓰기
  2. LG K30 Rear Facing Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
    댓글 쓰기
  3. LG K30 Rear Facing Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
    댓글 쓰기
  4. LG K30 Rear Facing Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to detach the battery connector from the logic board.
    댓글 쓰기
  5. LG K30 Rear Facing Camera Replacement: 5 단계, 이미지 2개 중 1개 LG K30 Rear Facing Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
    댓글 쓰기
  6. LG K30 Rear Facing Camera Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Use a spudger to carefully disconnect the front camera connector.
    • Use a spudger to disconnect the display cable connector.
    댓글 쓰기
  7. LG K30 Rear Facing Camera Replacement: 7 단계, 이미지 2개 중 1개 LG K30 Rear Facing Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the motherboard assembly from the display assembly with the a spudger or hand.
    댓글 쓰기
  8. LG K30 Rear Facing Camera Replacement, Rear Facing Camera: 8 단계, 이미지 2개 중 1개 LG K30 Rear Facing Camera Replacement, Rear Facing Camera: 8 단계, 이미지 2개 중 2개
    • Only pry on the tab, not the connector itself.
    • Use a Spudger to flip the release tab on the rear-facing camera cable ZIF connector.
    • Remove the rear-facing camera.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Vivek Kathrotiya
회원 가입일: 02/26/19
741 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 21
전체 시간: 803
