주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG K7 Home Button Cable Replacement
필요한 것
  1. LG K7 Home Button Cable Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG K7 Home Button Cable Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place a fingernail in slot at in the bottom edge of the phone.
    • Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Do not to pull too hard on the back panel or you may break it.
    댓글 쓰기
  2. LG K7 Home Button Cable Replacement: 2 단계, 이미지 2개 중 1개 LG K7 Home Button Cable Replacement: 2 단계, 이미지 2개 중 2개
    • Place a fingernail in the slot at the bottom edge of the battery.
    • Pull the battery out.
    댓글 쓰기
  3. LG K7 Home Button Cable Replacement, Home Button Cable: 3 단계, 이미지 3개 중 1개 LG K7 Home Button Cable Replacement, Home Button Cable: 3 단계, 이미지 3개 중 2개 LG K7 Home Button Cable Replacement, Home Button Cable: 3 단계, 이미지 3개 중 3개
    • Remove the nine frame screws with a JIS #00 screwdriver.
    • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
    • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
    댓글 쓰기
  4. LG K7 Home Button Cable Replacement: 4 단계, 이미지 2개 중 1개 LG K7 Home Button Cable Replacement: 4 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to separate the screen from the outer frame.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for easiest removal.
    • Do not bend the outer frame or the screen when separating them because this will severely damage the phone.
    댓글 쓰기
  5. LG K7 Home Button Cable Replacement: 5 단계, 이미지 3개 중 1개 LG K7 Home Button Cable Replacement: 5 단계, 이미지 3개 중 2개 LG K7 Home Button Cable Replacement: 5 단계, 이미지 3개 중 3개
    • The home button cable is attached to both the front and the back of the outer frame with adhesive. Orient the frame so that where the screen would be is facing you. Peel back the black rubber tab covering the wire.
    • Detach the cable from the frame with a plastic opening tool and let hang.
    • Flip the phone over and detach the button sensor part of the cable from the frame with a spudger.
    • Pull the backside cable through the hole when removing the component.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
James Ngo
회원 가입일: 01/19/18
461 평판
안내서 4개를 작성함
Cal Poly, Team S21-G5, Banghart Winter 2018 Cal Poly, Team S21-G5, Banghart Winter 2018 회원
CPSU-BANGHART-W18S21G5
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 29
전체 시간: 907
