주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG K7 T-Mobile Rear Phone Camera Replacement
필요한 것
  1. LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
    댓글 쓰기
  2. LG K7 T-Mobile Rear Phone  Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
    댓글 쓰기
  3. LG K7 T-Mobile Rear Phone  Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery.
    댓글 쓰기
  4. LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: 4 단계, 이미지 2개 중 1개 LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: 4 단계, 이미지 2개 중 2개
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
    댓글 쓰기
  5. LG K7 T-Mobile Rear Phone  Camera Replacement: 5 단계, 이미지 3개 중 1개 LG K7 T-Mobile Rear Phone  Camera Replacement: 5 단계, 이미지 3개 중 2개 LG K7 T-Mobile Rear Phone  Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Turn the phone over so the screen is facing up
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
    댓글 쓰기
  6. LG K7 T-Mobile Rear Phone  Camera Replacement: 6 단계, 이미지 3개 중 1개 LG K7 T-Mobile Rear Phone  Camera Replacement: 6 단계, 이미지 3개 중 2개 LG K7 T-Mobile Rear Phone  Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the ribbon cable that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Salem Jean
회원 가입일: 09/28/17
216 평판
안내서 1개를 작성함
USF Tampa, Team S2-G5, Nance Fall 2017 USF Tampa, Team S2-G5, Nance Fall 2017 회원
USFT-NANCE-F17S2G5
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 18
전체 시간: 778
