주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG L1200 Outer LCD Screen Replacement
필요한 것
  1. LG L1200 Outer LCD Screen Replacement, Inner LCD Screen: 1 단계, 이미지 1개 중 1개
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
    댓글 쓰기
  2. LG L1200 Outer LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
    댓글 쓰기
  3. LG L1200 Outer LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Using a T6 Torx screwdriver, remove all four screws.
    댓글 쓰기
  4. LG L1200 Outer LCD Screen Replacement: 4 단계, 이미지 3개 중 1개 LG L1200 Outer LCD Screen Replacement: 4 단계, 이미지 3개 중 2개 LG L1200 Outer LCD Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
    댓글 쓰기
  5. LG L1200 Outer LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 LG L1200 Outer LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
    댓글 쓰기
  6. LG L1200 Outer LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the tape from the bottom of the LCD screen.
    댓글 쓰기
  7. LG L1200 Outer LCD Screen Replacement: 7 단계, 이미지 3개 중 1개 LG L1200 Outer LCD Screen Replacement: 7 단계, 이미지 3개 중 2개 LG L1200 Outer LCD Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
    댓글 쓰기
  8. LG L1200 Outer LCD Screen Replacement: 8 단계, 이미지 3개 중 1개 LG L1200 Outer LCD Screen Replacement: 8 단계, 이미지 3개 중 2개 LG L1200 Outer LCD Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
    댓글 쓰기
  9. LG L1200 Outer LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 LG L1200 Outer LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
    댓글 쓰기
  10. LG L1200 Outer LCD Screen Replacement: 10 단계, 이미지 2개 중 1개 LG L1200 Outer LCD Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Use the spudger to remove the LCD screen from its backing.
    댓글 쓰기
  11. LG L1200 Outer LCD Screen Replacement, Outer LCD Screen: 11 단계, 이미지 1개 중 1개
    • The outer LCD screen can be found on the circuit board, which is attached to the back of the inner LCD screen.
    댓글 쓰기
  12. LG L1200 Outer LCD Screen Replacement: 12 단계, 이미지 2개 중 1개 LG L1200 Outer LCD Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Use an IPod opening tool to carefully lift the screen from its backing.
    • Use your finger to pull the screen forward.
    댓글 쓰기
  13. LG L1200 Outer LCD Screen Replacement: 13 단계, 이미지 2개 중 1개 LG L1200 Outer LCD Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Pull the screen and the tape ribbon off the circuit board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Joshua Herrmann
회원 가입일: 04/16/10
8 평판
안내서 8개를 작성함
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 회원
CPSU-MANESS-S10S6G14
4 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 28
전체 시간: 1,217
