주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG LX160 Back Casing Replacement
필요한 것
    1. LG LX160 Back Casing Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Place the phone on a flat surface with the back facing upward.
      • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
      댓글 쓰기
    2. LG LX160 Back Casing Replacement: 2 단계, 이미지 1개 중 1개
      • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
      댓글 쓰기
    3. LG LX160 Back Casing Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the battery completely from the phone and place the battery off to the side.
      댓글 쓰기
    1. LG LX160 Back Casing Replacement, Back Casing: 4 단계, 이미지 1개 중 1개
      • Now that the battery has been completely removed, hold the phone upright.
      • Pull off all rubber tabs covering the headphone jack and the power input port. Do this before continuing the next steps.
      댓글 쓰기
    2. LG LX160 Back Casing Replacement: 5 단계, 이미지 1개 중 1개
      • Flip the phone with the backside facing up.
      • Using the Phillips #00 Screwdriver, unscrew the 6 screws that hold the back casing together.
      댓글 쓰기
    3. LG LX160 Back Casing Replacement: 6 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Located at the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
      • Pull up gently on the orange wire until it comes loose. Do not be concerned with gentleness, it may require some force.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Shane Smith
회원 가입일: 01/14/10
1 평판
안내서 2개를 작성함
Cal Poly, Team 11-2, Forte Winter 2010 Cal Poly, Team 11-2, Forte Winter 2010 회원
CPSU-FORTE-W10S11G2
5 회원들
안내서 35개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 33
전체 시간: 2,331
