주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Muziq LX570 Keypad Replacement
필요한 것
    1. LG Muziq LX570 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG Muziq LX570 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Slide the battery cover release towards top of phone.
      • Place one finger at each side of the battery cover.
      • Lift and remove the battery cover.
      댓글 쓰기
    2. LG Muziq LX570 Keypad Replacement: 2 단계, 이미지 2개 중 1개 LG Muziq LX570 Keypad Replacement: 2 단계, 이미지 2개 중 2개
      • Place a finger at the top corner of the battery and lift out of the phone.
      댓글 쓰기
    1. LG Muziq LX570 Keypad Replacement, Rear Case: 3 단계, 이미지 2개 중 1개 LG Muziq LX570 Keypad Replacement, Rear Case: 3 단계, 이미지 2개 중 2개
      • Use the spudger to lift up the two screw covers at the top of the phone.
      • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
      댓글 쓰기
    2. LG Muziq LX570 Keypad Replacement: 4 단계, 이미지 3개 중 1개 LG Muziq LX570 Keypad Replacement: 4 단계, 이미지 3개 중 2개 LG Muziq LX570 Keypad Replacement: 4 단계, 이미지 3개 중 3개
      • Use the spudger to lift up the rear case from the phone.
      • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
      • Remove the rear case from the device.
      댓글 쓰기
    1. LG Muziq LX570 Keypad Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 LG Muziq LX570 Keypad Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 LG Muziq LX570 Keypad Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
      • Use the spudger to lift the motherboard from the phone.
      댓글 쓰기
    1. LG Muziq LX570 Keypad Replacement, Keypad: 6 단계, 이미지 3개 중 1개 LG Muziq LX570 Keypad Replacement, Keypad: 6 단계, 이미지 3개 중 2개 LG Muziq LX570 Keypad Replacement, Keypad: 6 단계, 이미지 3개 중 3개
      • Caution: The circuit board is connected via ribbon to the phone. Do not break this connection.
      • Note: The circuit board is attached by clips on both sides of the board. Detach each clip before removing the motherboard from the phone.
      • Use the spudger to detach the circuit board from the phone.
      댓글 쓰기
    2. LG Muziq LX570 Keypad Replacement: 7 단계, 이미지 3개 중 1개 LG Muziq LX570 Keypad Replacement: 7 단계, 이미지 3개 중 2개 LG Muziq LX570 Keypad Replacement: 7 단계, 이미지 3개 중 3개
      • Open the phone to expose the keypad.
      • Use your finger to push the keypad from the front towards the circuit board.
      • Remove the keypad from the phone.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Braden Burk
회원 가입일: 01/22/12
1 평판
안내서 5개를 작성함
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G29
4 회원들
안내서 49개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 33
전체 시간: 1,005
