주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Optimus 3D MicroSD/SIM Card Board Replacement
필요한 것
  1. LG Optimus 3D MicroSD/SIM Card Board Replacement, Back Cover Removal: 1 단계, 이미지 2개 중 1개 LG Optimus 3D MicroSD/SIM Card Board Replacement, Back Cover Removal: 1 단계, 이미지 2개 중 2개
    • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
    댓글 쓰기
  2. LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: 2 단계, 이미지 3개 중 1개 LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: 2 단계, 이미지 3개 중 2개 LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: 2 단계, 이미지 3개 중 3개
    • The battery is the large black rectangle towards the bottom half of the phone.
    • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
    댓글 쓰기
  3. LG Optimus 3D MicroSD/SIM Card Board Replacement, Screw Removal: 3 단계, 이미지 2개 중 1개 LG Optimus 3D MicroSD/SIM Card Board Replacement, Screw Removal: 3 단계, 이미지 2개 중 2개
    • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
    • 5.5mm length PH00 screws
    • 4mm length PH00 screws
    댓글 쓰기
  4. LG Optimus 3D MicroSD/SIM Card Board Replacement, Bottom Cover Removal: 4 단계, 이미지 2개 중 1개 LG Optimus 3D MicroSD/SIM Card Board Replacement, Bottom Cover Removal: 4 단계, 이미지 2개 중 2개
    • Gently pull down on the bottom cover to remove it.
    댓글 쓰기
  5. LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: 5 단계, 이미지 3개 중 1개 LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: 5 단계, 이미지 3개 중 2개 LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: 5 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, gently pry around the perimeter of the device.
    • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
    • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
    댓글 쓰기
  6. LG Optimus 3D MicroSD/SIM Card Board Replacement, Ribbon Cable Disconnection: 6 단계, 이미지 2개 중 1개 LG Optimus 3D MicroSD/SIM Card Board Replacement, Ribbon Cable Disconnection: 6 단계, 이미지 2개 중 2개
    • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
    댓글 쓰기
  7. LG Optimus 3D MicroSD/SIM Card Board Replacement, Adhesive Loosening: 7 단계, 이미지 1개 중 1개
    • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
    • Evenly heat the device in short intervals for about one minute.
    • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
    댓글 쓰기
  8. LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: 8 단계, 이미지 3개 중 1개 LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: 8 단계, 이미지 3개 중 2개 LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: 8 단계, 이미지 3개 중 3개
    • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
    • If the board is too difficult to separate than more heating may be required.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Dale Pearson
회원 가입일: 09/22/14
784 평판
안내서 6개를 작성함
USF Tampa, Team 10-6, Brown Fall 2014 USF Tampa, Team 10-6, Brown Fall 2014 회원
USFT-BROWN-F14S10G6
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 48
전체 시간: 1,373
