주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Optimus F3 Charging port unit Replacement
필요한 것
  1. LG Optimus F3 Charging port unit  Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Turn the device so that the back faces up.
    • It is easiest to open the case near the charging port located at the bottom of the phone.
    • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
    댓글 쓰기
  2. LG Optimus F3 Charging port unit  Replacement: 2 단계, 이미지 1개 중 1개
    • With back case removed, the battery is visible. The battery is the large square object.
    • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
    댓글 쓰기
  3. LG Optimus F3 Charging port unit  Replacement: 3 단계, 이미지 1개 중 1개
    • Remove 10 1.0 mm screws located on the back of the device.
    • Refer to the outlined locations in the image for the screws.
    댓글 쓰기
  4. LG Optimus F3 Charging port unit  Replacement: 4 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to separate the inner case from the device.
    • Wedge the plastic opening tool between the case.
    • Wiggle the tool and use leverage to pry the case apart.
    댓글 쓰기
  5. LG Optimus F3 Charging port unit  Replacement: 5 단계, 이미지 1개 중 1개
    • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
    • Use the plastic opening tool to separate the camera from the motherboard.
    • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
    댓글 쓰기
  6. LG Optimus F3 Charging port unit  Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to disconnect and remove the rear facing camera.
    댓글 쓰기
  7. LG Optimus F3 Charging port unit  Replacement: 7 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
    • Note that the sim card and the memory card connector are one unit.
    • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
    댓글 쓰기
  8. LG Optimus F3 Charging port unit  Replacement: 8 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to remove the charging port unit.
    • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
    댓글 쓰기
  9. LG Optimus F3 Charging port unit  Replacement: 9 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
    • The motherboard is an L-shaped unit above and to the left of the battery encasement.
    • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
    댓글 쓰기
  10. LG Optimus F3 Charging port unit  Replacement, Charging port unit: 10 단계, 이미지 1개 중 1개
    • Remove one 1.0 mm screw.
    댓글 쓰기
  11. LG Optimus F3 Charging port unit  Replacement: 11 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to remove front glass protector.
    댓글 쓰기
  12. LG Optimus F3 Charging port unit  Replacement: 12 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to remove front glass cover carefully. Try not to break the connector.
    댓글 쓰기
  13. LG Optimus F3 Charging port unit  Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the front facing camera.
    댓글 쓰기
  14. LG Optimus F3 Charging port unit  Replacement: 14 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to carefully remove the home button board. It is attached with double-sided tape.
    댓글 쓰기
  15. LG Optimus F3 Charging port unit  Replacement: 15 단계, 이미지 1개 중 1개
    댓글 쓰기
  16. LG Optimus F3 Charging port unit  Replacement: 16 단계, 이미지 1개 중 1개
    • You are all set.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jonathan Fang
회원 가입일: 10/28/15
356 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-5, Miles Fall 2015 UMass Dartmouth, Team 1-5, Miles Fall 2015 회원
UMASSD-MILES-F15S1G5
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 36
전체 시간: 916
