주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Optimus G Pro Midframe Replacement
필요한 것
  1. LG Optimus G Pro Midframe Replacement, Remove Back Cover.: 1 단계, 이미지 1개 중 1개
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
    댓글 쓰기
  2. LG Optimus G Pro Midframe Replacement, Remove the Battery.: 2 단계, 이미지 1개 중 1개
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
    댓글 쓰기
  3. LG Optimus G Pro Midframe Replacement, Screw Removal: 3 단계, 이미지 2개 중 1개 LG Optimus G Pro Midframe Replacement, Screw Removal: 3 단계, 이미지 2개 중 2개
    • Make sure you remove the battery first. You will see that there are 14 screws on the back of the inner case. Use the Phillips head screwdriver to remove each of the screws, make sure to put the screws in a safe place where they will not get lost.
    댓글 쓰기
  4. LG Optimus G Pro Midframe Replacement, Remove Cover: 4 단계, 이미지 1개 중 1개
    • Once you have removed all the screws, you can begin removing the inside cover.
    • Insert the opening tool using a sliding motion into one of the corners and move it along the edges of the inside cover. This will loosen the edges and the inside cover will pry apart from the shell.
    댓글 쓰기
  5. LG Optimus G Pro Midframe Replacement, Completion: 5 단계, 이미지 1개 중 1개
    • The inner cover is now removed, you now have access to the many parts on the inside of the phone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Wesley Pate
회원 가입일: 09/25/14
1,641 평판
안내서 7개를 작성함
USF Tampa, Team 15-5, Remmell Fall 2014 USF Tampa, Team 15-5, Remmell Fall 2014 회원
USFT-REMMELL-F14S15G5
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 2,294
