주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Optimus T Button Replacement
필요한 것
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using a prying device, such as a Spudger, remove the phone's back cover. At the top of the phone, there's an indentation to put the Spudger into to pop the case off.
    댓글 쓰기
  1. LG Optimus T Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery. There's an indentation to the left of the camera lens to pull up on the battery with your finger.
    댓글 쓰기
  2. LG Optimus T Button Replacement: 3 단계, 이미지 1개 중 1개
    • Use a J0 screwdriver to remove the six 4.5 mm screws.
    댓글 쓰기
  3. LG Optimus T Button Replacement: 4 단계, 이미지 2개 중 1개 LG Optimus T Button Replacement: 4 단계, 이미지 2개 중 2개
    • Remove interior case. Insert the spudger into the indentations at the top or bottom of the phone to pry off the interior case.
    • You might have difficulty popping the case off. You may use the metal spudger if the plastic one fails. Be cautious when using it, as the metal spudger may damage your phone.
    댓글 쓰기
  4. LG Optimus T Button Replacement: 5 단계, 이미지 3개 중 1개 LG Optimus T Button Replacement: 5 단계, 이미지 3개 중 2개 LG Optimus T Button Replacement: 5 단계, 이미지 3개 중 3개
    • Remove power button found on top of the phone.
    • Remove the volume button found on the side of the phone.
    • There is an indentation that has been marked near the edge that part of the volume button inserts in to. You will use this when reassembling your phone.
    • When reassembling your phone, place buttons on the metal nodes that have been marked.
    댓글 쓰기
  5. LG Optimus T Button Replacement: 6 단계, 이미지 1개 중 1개
    • Pull up on connector tab.
    댓글 쓰기
  6. LG Optimus T Button Replacement: 7 단계, 이미지 2개 중 1개 LG Optimus T Button Replacement: 7 단계, 이미지 2개 중 2개
    • Remove SD card mount. Insert a plastic opening tool on the right side to pop off.
    댓글 쓰기
  7. LG Optimus T Button Replacement: 8 단계, 이미지 2개 중 1개 LG Optimus T Button Replacement: 8 단계, 이미지 2개 중 2개
    • There are 4 retaining points to insert a plastic opening tool into and pop off panel.
    댓글 쓰기
  8. LG Optimus T Button Replacement: 9 단계, 이미지 1개 중 1개
    • Remove 2 black J0 Phillip's head 1.8 mm screws from charging port.
    • Charging port and motherboard are connected.
    • Remove motherboard.
    댓글 쓰기
  9. LG Optimus T Button Replacement: 10 단계, 이미지 2개 중 1개 LG Optimus T Button Replacement: 10 단계, 이미지 2개 중 2개
    • Pop off home buttons.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Patrick Esguerra
회원 가입일: 02/07/17
126 평판
안내서 1개를 작성함
Ohio State, Team 1-3, Wilder Spring 2017 Ohio State, Team 1-3, Wilder Spring 2017 회원
OSU-WILDER-S17S1G3
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 28
전체 시간: 432
