주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Optimus T Screen Replacement
필요한 것
  1. LG Optimus T Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 LG Optimus T Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 LG Optimus T Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using the plastic opening tool to remove the phone’s back cover. At the top of the phone, there’s an indentation to put the tool into to pop the case off.
    댓글 쓰기
  2. LG Optimus T Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery. There’s an indentation to the left of the camera lens.
    댓글 쓰기
  3. LG Optimus T Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the six (6), J0 Phillip's head, 4.5mm screws.
    • Be sure to retain all screws for reassembly.
    댓글 쓰기
  4. LG Optimus T Screen Replacement: 4 단계, 이미지 2개 중 1개 LG Optimus T Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Remove interior case. There are indentations on the top and bottom of the phone. Using a spudger, remove the interior case.
    • You might have difficulty popping the interior case off, and a more durable prying device may be needed.
    댓글 쓰기
  5. LG Optimus T Screen Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Pull up connector tab
    • Connector tabs may be difficult to remove, and tweezers may be required to assist removal.
    댓글 쓰기
  6. LG Optimus T Screen Replacement: 6 단계, 이미지 2개 중 1개 LG Optimus T Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Remove SD card mount. Use a plastic opening tool to assist removal.
    댓글 쓰기
  7. LG Optimus T Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Use a J0 screwdriver to remove two 1.8mm screws from the charging port.
    • Charging port and motherboard are connected.
    댓글 쓰기
  8. LG Optimus T Screen Replacement: 8 단계, 이미지 2개 중 1개 LG Optimus T Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Remove connector tab. Then remove the motherboard.
    댓글 쓰기
  9. LG Optimus T Screen Replacement: 9 단계, 이미지 2개 중 1개 LG Optimus T Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Using a spudger, gently pry off the metal panel on the back of the screen attached by 4 retaining points.
    • Remove the screen from the front of your device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Edward Farris
회원 가입일: 02/07/17
112 평판
안내서 1개를 작성함
Ohio State, Team 1-3, Wilder Spring 2017 Ohio State, Team 1-3, Wilder Spring 2017 회원
OSU-WILDER-S17S1G3
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 399
