주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Refrigerator Compressor Run Capacitor Replacement
필요한 것
  1. LG Refrigerator Compressor Run Capacitor Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    댓글 쓰기
  2. LG Refrigerator Compressor Run Capacitor Replacement, Unfasten the control board cover: 2 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
    댓글 쓰기
  3. LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: 3 단계, 이미지 3개 중 1개 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: 3 단계, 이미지 3개 중 2개 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: 3 단계, 이미지 3개 중 3개
    • Tilt the top edge of the cover toward you and lift it off.
    댓글 쓰기
  4. LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: 4 단계, 이미지 3개 중 1개 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: 4 단계, 이미지 3개 중 2개 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: 4 단계, 이미지 3개 중 3개
    • Pull the left edge of the capacitor toward you to unclip it.
    • Handle the capacitor carefully as it may still be charged, and can give a dangerous and painful electrical shock. Avoid touching the terminals with your fingers or hands.
    • For information on capacitor safety, click here.
    댓글 쓰기
  5. LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: 5 단계, 이미지 3개 중 1개 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: 5 단계, 이미지 3개 중 2개 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: 5 단계, 이미지 3개 중 3개
    • Pull the connector straight off the capacitor to disconnect it.
    • Remove the capacitor.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
40,140 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 31,437개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 24
지난 30일: 143
전체 시간: 3,311
