주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Refrigerator Control Board Replacement
필요한 것
  1. LG Refrigerator Control Board Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    댓글 쓰기
  2. LG Refrigerator Control Board Replacement, Unfasten the control board cover: 2 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
    댓글 쓰기
  3. LG Refrigerator Control Board Replacement, Remove the control board cover: 3 단계, 이미지 3개 중 1개 LG Refrigerator Control Board Replacement, Remove the control board cover: 3 단계, 이미지 3개 중 2개 LG Refrigerator Control Board Replacement, Remove the control board cover: 3 단계, 이미지 3개 중 3개
    • Tilt the top edge of the cover toward you and lift it off.
    댓글 쓰기
  4. LG Refrigerator Control Board Replacement, Disconnect the control board: 4 단계, 이미지 3개 중 1개 LG Refrigerator Control Board Replacement, Disconnect the control board: 4 단계, 이미지 3개 중 2개 LG Refrigerator Control Board Replacement, Disconnect the control board: 4 단계, 이미지 3개 중 3개
    • Note the position of each of the connectors, before disconnecting them. A photo is very valuable for keeping track, and taking several as you progress may be helpful.
    • Squeeze and pull the connectors to disconnect them from the control board.
    • Make sure to fully reconnect each connector when reassembling.
    댓글 쓰기
  5. LG Refrigerator Control Board Replacement, Release the control board: 5 단계, 이미지 3개 중 1개 LG Refrigerator Control Board Replacement, Release the control board: 5 단계, 이미지 3개 중 2개 LG Refrigerator Control Board Replacement, Release the control board: 5 단계, 이미지 3개 중 3개
    • Use your thumb to pry up and release the top left retaining clip securing the control board.
    • With your other hand, pull the top left corner of the control board out to loosen it.
    댓글 쓰기
  6. LG Refrigerator Control Board Replacement: 6 단계, 이미지 3개 중 1개 LG Refrigerator Control Board Replacement: 6 단계, 이미지 3개 중 2개 LG Refrigerator Control Board Replacement: 6 단계, 이미지 3개 중 3개
    • Repeat this process for each tab down the left edge of the control board as well as the top and bottom edges.
    댓글 쓰기
  7. LG Refrigerator Control Board Replacement, Remove the control board: 7 단계, 이미지 1개 중 1개
    • Lift the control board out by its edges and remove it.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
Bill Gilbert
회원 가입일: 06/30/22
40,137 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 31,364개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 44
지난 30일: 239
전체 시간: 4,847
