주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Refrigerator Freezer Ice Maker Replacement
필요한 것
    1. LG Refrigerator Freezer Ice Maker Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      댓글 쓰기
    1. LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: 2 단계, 이미지 2개 중 1개 LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: 2 단계, 이미지 2개 중 2개
      • Pull open the freezer door fully.
      댓글 쓰기
    2. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: 3 단계, 이미지 3개 중 1개 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: 3 단계, 이미지 3개 중 2개 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: 3 단계, 이미지 3개 중 3개
      • Lift and remove the upper pull-out drawer.
      • Lift and remove the main drawer bin.
      댓글 쓰기
    3. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: 4 단계, 이미지 3개 중 1개 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: 4 단계, 이미지 3개 중 2개 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: 4 단계, 이미지 3개 중 3개
      • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
      • Lift the cover off of the rail and remove it.
      • Repeat this procedure for the left drawer rail cover.
      댓글 쓰기
    4. LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: 5 단계, 이미지 2개 중 1개 LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: 5 단계, 이미지 2개 중 2개
      • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
      • Hold the drawer rail cover flush against the side of the drawer rail.
      • You should feel the locking tabs protruding.
      • Push the rail cover straight downward to install. It should click into place.
      댓글 쓰기
    5. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: 6 단계, 이미지 2개 중 1개 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: 6 단계, 이미지 2개 중 2개
      • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
      댓글 쓰기
    6. LG Refrigerator Freezer Ice Maker Replacement: 7 단계, 이미지 3개 중 1개 LG Refrigerator Freezer Ice Maker Replacement: 7 단계, 이미지 3개 중 2개 LG Refrigerator Freezer Ice Maker Replacement: 7 단계, 이미지 3개 중 3개
      • Lift the front of the drawer up.
      • Pull the drawer toward you to release the drawer from the drawer slides.
      • Remove the freezer drawer.
      댓글 쓰기
    1. LG Refrigerator Freezer Ice Maker Replacement, Release the ice maker: 8 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove the screws securing the ice maker to the top of the freezer compartment.
      댓글 쓰기
    2. LG Refrigerator Freezer Ice Maker Replacement: 9 단계, 이미지 3개 중 1개 LG Refrigerator Freezer Ice Maker Replacement: 9 단계, 이미지 3개 중 2개 LG Refrigerator Freezer Ice Maker Replacement: 9 단계, 이미지 3개 중 3개
      • Insert a flat-blade screwdriver into the slot located on the right edge of the ice maker.
      • Pry outward with the screwdriver to release the locking tab securing the ice maker to the fridge.
      • When the tab releases, pull the right front corner of the ice maker down.
      댓글 쓰기
    3. LG Refrigerator Freezer Ice Maker Replacement: 10 단계, 이미지 1개 중 1개
      • Repeat the previous operation on the left side of the ice maker to release it.
      댓글 쓰기
    4. LG Refrigerator Freezer Ice Maker Replacement: 11 단계, 이미지 3개 중 1개 LG Refrigerator Freezer Ice Maker Replacement: 11 단계, 이미지 3개 중 2개 LG Refrigerator Freezer Ice Maker Replacement: 11 단계, 이미지 3개 중 3개
      • Grasp the front edge of the ice maker and pull it towards you.
      • Lower the ice maker.
      댓글 쓰기
    5. LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: 12 단계, 이미지 3개 중 1개 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: 12 단계, 이미지 3개 중 2개 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: 12 단계, 이미지 3개 중 3개
      • Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
      • Remove the ice maker.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
40,177 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 61,258개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 139
지난 30일: 560
전체 시간: 9,714
