주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Refrigerator Upper Ice Maker Assembly Replacement
필요한 것
    1. LG Refrigerator Upper Ice Maker Assembly Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      댓글 쓰기
    1. LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
      • Open both refrigerator doors fully.
      댓글 쓰기
    1. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: 3 단계, 이미지 2개 중 1개 LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: 3 단계, 이미지 2개 중 2개
      • Use a #2 Philips driver to remove the screws that secure the ice maker assembly to the refrigerator door.
      댓글 쓰기
    2. LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 4 단계, 이미지 3개 중 1개 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 4 단계, 이미지 3개 중 2개 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 4 단계, 이미지 3개 중 3개
      • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
      • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
      댓글 쓰기
    3. LG Refrigerator Upper Ice Maker Assembly Replacement: 5 단계, 이미지 3개 중 1개 LG Refrigerator Upper Ice Maker Assembly Replacement: 5 단계, 이미지 3개 중 2개 LG Refrigerator Upper Ice Maker Assembly Replacement: 5 단계, 이미지 3개 중 3개
      • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
      • Squeeze the connector at the top of the ice maker assembly to release it.
      • Pull the connector straight down to disconnect it.
      댓글 쓰기
    4. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly: 6 단계, 이미지 1개 중 1개
      • Remove the ice maker assembly.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
40,159 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 38,655개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 88
전체 시간: 1,534
