주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Spectrum Motherboard Replacement
필요한 것
  1. LG Spectrum Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG Spectrum Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
    댓글 쓰기
  2. LG Spectrum Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
    댓글 쓰기
  3. LG Spectrum Motherboard Replacement, Sim/SD Port: 3 단계, 이미지 2개 중 1개 LG Spectrum Motherboard Replacement, Sim/SD Port: 3 단계, 이미지 2개 중 2개
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnetic mat to keep the screws in one place.
    댓글 쓰기
  4. LG Spectrum Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
    댓글 쓰기
  5. LG Spectrum Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
    댓글 쓰기
  6. LG Spectrum Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Hook the plastic opening tool underneath the plate and gently lift it up.
    댓글 쓰기
  7. LG Spectrum Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
    댓글 쓰기
  8. LG Spectrum Motherboard Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 LG Spectrum Motherboard Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to lift up the connector that holds the camera to the board.
    댓글 쓰기
  9. LG Spectrum Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Pull the camera gently out of its housing in the motherboard with your fingers.
    댓글 쓰기
  10. LG Spectrum Motherboard Replacement: 10 단계, 이미지 2개 중 1개 LG Spectrum Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, gently pry up the audio port connector.
    댓글 쓰기
  11. LG Spectrum Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the audio port from the motherboard with either your hand or the plastic opening tool.
    댓글 쓰기
  12. LG Spectrum Motherboard Replacement: 12 단계, 이미지 2개 중 1개 LG Spectrum Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Detach the two cable connector wires from the motherboard with the plastic opening tool.
    • Detach the remaining five connectors from the phone with the plastic opening tool.
    댓글 쓰기
  13. LG Spectrum Motherboard Replacement: 13 단계, 이미지 2개 중 1개 LG Spectrum Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Hook the plastic opening tool underneath the motherboard and firmly lift it out of the phone casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Aiman Sallam
회원 가입일: 02/10/16
506 평판
안내서 5개를 작성함
USF Tampa, Team 1-4, Sullivan Spring 2016 USF Tampa, Team 1-4, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G4
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 29
전체 시간: 927
