주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Stylo 3 Plus Battery Replacement
필요한 것
  1. LG Stylo 3 Plus Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 LG Stylo 3 Plus Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 LG Stylo 3 Plus Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
    댓글 쓰기
  2. LG Stylo 3 Plus Battery Replacement, Battery: 2 단계, 이미지 3개 중 1개 LG Stylo 3 Plus Battery Replacement, Battery: 2 단계, 이미지 3개 중 2개 LG Stylo 3 Plus Battery Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Patricia Pires Dias
회원 가입일: 10/26/18
945 평판
안내서 5개를 작성함
UMass Dartmouth, Team S2-G6, Peak Fall 2018 UMass Dartmouth, Team S2-G6, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G6
3 회원들
안내서 15개를 작성함
4가이드 댓글
Thank you for your help. When I took the battery out one of the 4 gold prongs is dirty tried to clean with a toothbrush, do you have any ideas to clean it?
pmorin3887 - 답글 공유
The gold prong in the phone where the battery is
pmorin3887 - 답글 공유
my phone goes from fully charged to 0 in a few minutes, I took the battery out and seen it was a bit bubbled. I have so far bought 3 new batteries for my phone and every time when I turn it on I get invalid battery and it turns off I have left the battery out for a week to reset it but I still get the error when I turn it on… please somebody help
crystalbic - 답글 공유
It is &&^&@@ up you just got to get a new one you know you got to live to die even man-made machines I'm sorry I hope you can find a way to get over it and move on
Deez Blaccnuts - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 47
전체 시간: 4,717
