주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Thrill 4G SIM/Micro SD Card Replacement
필요한 것
  1. LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: 1 단계, 이미지 2개 중 1개 LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: 1 단계, 이미지 2개 중 2개
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
    댓글 쓰기
  2. LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: 2 단계, 이미지 2개 중 1개 LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: 2 단계, 이미지 2개 중 2개
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
    댓글 쓰기
  3. LG Thrill 4G SIM/Micro SD Card Replacement, Screw Removal: 3 단계, 이미지 1개 중 1개
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
    댓글 쓰기
  4. LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: 4 단계, 이미지 2개 중 1개 LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: 4 단계, 이미지 2개 중 2개
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
    댓글 쓰기
  5. LG Thrill 4G SIM/Micro SD Card Replacement, Buttons: 5 단계, 이미지 1개 중 1개
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
    댓글 쓰기
  6. LG Thrill 4G SIM/Micro SD Card Replacement: 6 단계, 이미지 3개 중 1개 LG Thrill 4G SIM/Micro SD Card Replacement: 6 단계, 이미지 3개 중 2개 LG Thrill 4G SIM/Micro SD Card Replacement: 6 단계, 이미지 3개 중 3개
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
    댓글 쓰기
  7. LG Thrill 4G SIM/Micro SD Card Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the six Phillips #00 screws within the mid-cover bezel.
    댓글 쓰기
  8. LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: 8 단계, 이미지 3개 중 1개 LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: 8 단계, 이미지 3개 중 2개 LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: 8 단계, 이미지 3개 중 3개
    • Utilize a spudger or plastic opening tool and gently disconnect the ribbon cable that is attached to the black micro-SIM card board.
    댓글 쓰기
  9. LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: 9 단계, 이미지 3개 중 1개 LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: 9 단계, 이미지 3개 중 2개 LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: 9 단계, 이미지 3개 중 3개
    • Carefully pry the board up to detach it from its place in the phone.
    • Make sure to pry off the small tab connected to the camera unit as well.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Khbero Baker
회원 가입일: 01/19/15
128 평판
안내서 1개를 작성함
USF Tampa, Team 1-6, Blackwell Winter 2015 USF Tampa, Team 1-6, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S1G6
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 909
