주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG V10 Motherboard Replacement
필요한 것
  1. LG V10 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
    댓글 쓰기
  2. LG V10 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 LG V10 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
    댓글 쓰기
  3. LG V10 Motherboard Replacement, Motherboard: 3 단계, 이미지 3개 중 1개 LG V10 Motherboard Replacement, Motherboard: 3 단계, 이미지 3개 중 2개 LG V10 Motherboard Replacement, Motherboard: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a screwdriver with a J000 Phillips bit, remove the fourteen 3.175 mm screws.
    • Using a plastic opening tool, pry part of the panel up starting from the sides of the battery slot.
    • Use plastic tweezers to release the rest of the panel from plastic bits holding it in place and pry the panel up around the sides surrounding the fingerprint sensor and camera lens; set the back panel off to the side.
    댓글 쓰기
  4. LG V10 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 LG V10 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully disconnect these two connectors by using the flat end of the plastic spudger to wedge the connectors away from the motherboard.
    • Use the plastic tweezers to pry the motherboard out from the plastic bits holding it in place.
    댓글 쓰기
결론
After replacing the old motherboard, follow these instructions in reverse order to reassemble the LG V10.
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Joseph
회원 가입일: 09/25/17
1,005 평판
안내서 4개를 작성함
USF Tampa, Team S16-G3, Eyestone Fall 2017 USF Tampa, Team S16-G3, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G3
2 회원들
안내서 12개를 작성함
1가이드 댓글
great guide !
Jordan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 37
전체 시간: 8,597
