주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG V20 Loudspeaker Replacement
필요한 것
  1. LG V20 Loudspeaker Replacement, Battery: 1 단계, 이미지 3개 중 1개 LG V20 Loudspeaker Replacement, Battery: 1 단계, 이미지 3개 중 2개 LG V20 Loudspeaker Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
    • Be careful not to deform or puncture the battery.
    • Pry up and remove the battery.
    댓글 쓰기
  2. LG V20 Loudspeaker Replacement, Midframe Assembly: 2 단계, 이미지 1개 중 1개
    • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
    댓글 쓰기
  3. LG V20 Loudspeaker Replacement: 3 단계, 이미지 2개 중 1개 LG V20 Loudspeaker Replacement: 3 단계, 이미지 2개 중 2개
    • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
    • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
    댓글 쓰기
  4. LG V20 Loudspeaker Replacement: 4 단계, 이미지 2개 중 1개 LG V20 Loudspeaker Replacement: 4 단계, 이미지 2개 중 2개
    • Flip the phone and insert an opening pick in the gap you created.
    • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
    댓글 쓰기
  5. LG V20 Loudspeaker Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the frame section.
    • Repeat this procedure with the frame section on the other end of the phone.
    • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
    댓글 쓰기
  6. LG V20 Loudspeaker Replacement: 6 단계, 이미지 2개 중 1개 LG V20 Loudspeaker Replacement: 6 단계, 이미지 2개 중 2개
    • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
    댓글 쓰기
  7. LG V20 Loudspeaker Replacement: 7 단계, 이미지 2개 중 1개 LG V20 Loudspeaker Replacement: 7 단계, 이미지 2개 중 2개
    • The cover of the motherboard is held in its place by several plastic clamps.
    • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
    댓글 쓰기
  8. LG V20 Loudspeaker Replacement: 8 단계, 이미지 2개 중 1개 LG V20 Loudspeaker Replacement: 8 단계, 이미지 2개 중 2개
    • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
    댓글 쓰기
  9. LG V20 Loudspeaker Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the motherboard cover.
    댓글 쓰기
  10. LG V20 Loudspeaker Replacement, Loudspeaker: 10 단계, 이미지 2개 중 1개 LG V20 Loudspeaker Replacement, Loudspeaker: 10 단계, 이미지 2개 중 2개
    • The loudspeaker is attached to the cover of the motherboard by a tight plastic clamp.
    • Flip the motherboard cover and pull the loudspeaker out of the plastic clamp at the lower end of it. Take care not to break the clamp.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Elliot Rockett
회원 가입일: 04/26/17
140 평판
안내서 1개를 작성함
Cal Poly, Team S22-G5, Livingston Spring 2017 Cal Poly, Team S22-G5, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G5
4 회원들
안내서 50개를 작성함
4가이드 댓글
Step 5 isn’t quite right. You can pry the speaker up like that, but you need to pull on the speaker to remove it, not pry it up. Pulling it out is difficult without removing more of the framing. I’d advise extreme caution removing the speaker like they have illustrated without pulling up more of the framing around the outside of the phone first. It’s more screws to deal with, but it’s better than breaking anything.
Cody Billings - 답글 공유
Just completed. New speaker seemed to seed nicely. Upon restarting phone no sound emitting from any speaker. Reinstalled faulty speaker and same results. Reinstalled new speaker and did a reset of factory settings, still no sound emitting from music, notifications, etc. This tutorial suggested straight forward plug and play. Disappointed.
Brent - 답글 공유
Did you get the speaker fixed yet?
Roman Kononov - 답글 공유
nice tutorial !! saved my V20 !!!
Karo - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 13
지난 30일: 38
전체 시간: 4,008
