주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG V20 Primary Rear-Facing Camera Replacement
필요한 것
    1. LG V20 Primary Rear-Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 LG V20 Primary Rear-Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 LG V20 Primary Rear-Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
      • Be careful not to deform or puncture the battery.
      • Pry up and remove the battery.
      댓글 쓰기
    1. LG V20 Primary Rear-Facing Camera Replacement, Midframe Assembly: 2 단계, 이미지 1개 중 1개
      • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
      댓글 쓰기
    2. LG V20 Primary Rear-Facing Camera Replacement: 3 단계, 이미지 2개 중 1개 LG V20 Primary Rear-Facing Camera Replacement: 3 단계, 이미지 2개 중 2개
      • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
      • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
      댓글 쓰기
    3. LG V20 Primary Rear-Facing Camera Replacement: 4 단계, 이미지 2개 중 1개 LG V20 Primary Rear-Facing Camera Replacement: 4 단계, 이미지 2개 중 2개
      • Flip the phone and insert an opening pick in the gap you created.
      • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
      댓글 쓰기
    4. LG V20 Primary Rear-Facing Camera Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the frame section.
      • Repeat this procedure with the frame section on the other end of the phone.
      • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
      댓글 쓰기
    5. LG V20 Primary Rear-Facing Camera Replacement: 6 단계, 이미지 2개 중 1개 LG V20 Primary Rear-Facing Camera Replacement: 6 단계, 이미지 2개 중 2개
      • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
      댓글 쓰기
    6. LG V20 Primary Rear-Facing Camera Replacement: 7 단계, 이미지 2개 중 1개 LG V20 Primary Rear-Facing Camera Replacement: 7 단계, 이미지 2개 중 2개
      • The cover of the motherboard is held in its place by several plastic clamps.
      • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
      댓글 쓰기
    7. LG V20 Primary Rear-Facing Camera Replacement: 8 단계, 이미지 2개 중 1개 LG V20 Primary Rear-Facing Camera Replacement: 8 단계, 이미지 2개 중 2개
      • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
      댓글 쓰기
    8. LG V20 Primary Rear-Facing Camera Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the motherboard cover.
      댓글 쓰기
    1. LG V20 Primary Rear-Facing Camera Replacement, Front-Facing Camera: 10 단계, 이미지 2개 중 1개 LG V20 Primary Rear-Facing Camera Replacement, Front-Facing Camera: 10 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use the flat end of a spudger to disconnect the front camera flex cable.
      • If you want to go on and remove the motherboard assembly, there is no need to remove the front facing camera after disconnecting it. However if you feel uncertain, carefully remove it with a pair of tweezers.
      • Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
      댓글 쓰기
    1. LG V20 Primary Rear-Facing Camera Replacement, Motherboard Assembly: 11 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
      • The second rear camera will come out with the motherboard since it is connected on the other side.
      • You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
      댓글 쓰기
    2. LG V20 Primary Rear-Facing Camera Replacement: 12 단계, 이미지 1개 중 1개
      • Disconnect the display flex cable with the flat end of a spudger.
      댓글 쓰기
    3. LG V20 Primary Rear-Facing Camera Replacement: 13 단계, 이미지 2개 중 1개 LG V20 Primary Rear-Facing Camera Replacement: 13 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to lift up the motherboard assembly until you can get a good grip.
      • Carefully lift up the motherboard assembly and remove it.
      댓글 쓰기
    1. LG V20 Primary Rear-Facing Camera Replacement, Primary Rear-Facing Camera: 14 단계, 이미지 2개 중 1개 LG V20 Primary Rear-Facing Camera Replacement, Primary Rear-Facing Camera: 14 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Flip the motherboard assembly and use the flat end of a spudger to carefully disconnect the flex cable of the rear camera.
      • Use a pair of tweezers to remove the rear camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Garrett Janney
회원 가입일: 04/26/17
909 평판
안내서 4개를 작성함
Cal Poly, Team S22-G5, Livingston Spring 2017 Cal Poly, Team S22-G5, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G5
4 회원들
안내서 70개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 41
전체 시간: 7,096
