주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG VX5600 Plastic Screen Protector Replacement
필요한 것
  1. LG VX5600 Plastic Screen Protector Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG VX5600 Plastic Screen Protector Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
    • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
    댓글 쓰기
  2. LG VX5600 Plastic Screen Protector Replacement: 2 단계, 이미지 2개 중 1개 LG VX5600 Plastic Screen Protector Replacement: 2 단계, 이미지 2개 중 2개
    • Insert your finger into the small indentation above the battery.
    • Push down on the battery and pull it away from the phone; it will pop out.
    댓글 쓰기
  3. LG VX5600 Plastic Screen Protector Replacement, Plastic Screen Protector: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to remove the two rubber covers found at the left and right corners below the inside screen.
    댓글 쓰기
  4. LG VX5600 Plastic Screen Protector Replacement: 4 단계, 이미지 1개 중 1개
    • Grasp the phone and rotate it 90 degrees counterclockwise for a better grip.
    • Unscrew the two 3.0-mm Phillips #000 screws, found under the rubber covers at the bottom left and right corners.
    • Some of the pictures show the bottom of the phone disassembled. It is unneccessary to disassemble the bottom of the phone for this guide.
    댓글 쓰기
  5. LG VX5600 Plastic Screen Protector Replacement: 5 단계, 이미지 2개 중 1개 LG VX5600 Plastic Screen Protector Replacement: 5 단계, 이미지 2개 중 2개
    • Hold the opened phone upright.
    • Use the spudger to pry around the edges of the phone and detach the tabs.
    • Make sure all the tabs around the grey cover are detached. They are located on the top and on both sides of the screen.
    댓글 쓰기
  6. LG VX5600 Plastic Screen Protector Replacement: 6 단계, 이미지 1개 중 1개
    • Use your finger to lift up the grey plastic cover.
    • Use the tweezers to grasp the plastic screen, and pull the plastic screen protector up and out of the phone.
    • The plastic screen protector is adhered with glue to the back of the phone, so a little force is required to remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Irena Tran
회원 가입일: 06/04/13
435 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 28
전체 시간: 805
