주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG VX8700 Ear Piece Replacement
필요한 것
  1. LG VX8700 Ear Piece Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG VX8700 Ear Piece Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
    댓글 쓰기
  2. LG VX8700 Ear Piece Replacement: 2 단계, 이미지 2개 중 1개 LG VX8700 Ear Piece Replacement: 2 단계, 이미지 2개 중 2개
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
    댓글 쓰기
  3. LG VX8700 Ear Piece Replacement, Front Bezel: 3 단계, 이미지 1개 중 1개
    • Turn your phone around and open the flip phone. The screen is now facing you.
    • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
    • Remove the two grey screw-covers.
    댓글 쓰기
  4. LG VX8700 Ear Piece Replacement: 4 단계, 이미지 2개 중 1개 LG VX8700 Ear Piece Replacement: 4 단계, 이미지 2개 중 2개
    • Use the ejection tab at the top to remove the screen.
    • There is a gap between the case and the screen near the ear piece.
    • Insert the plastic opening tool in the gap and pry up the screen.
    • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
    댓글 쓰기
  5. LG VX8700 Ear Piece Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
    댓글 쓰기
  6. LG VX8700 Ear Piece Replacement: 6 단계, 이미지 2개 중 1개 LG VX8700 Ear Piece Replacement: 6 단계, 이미지 2개 중 2개
    • Turn your phone around. The battery side will be facing you.
    • Insert the plastic opening tool into the groove to remove the top cover of the phone.
    • Carefully open the cover.
    댓글 쓰기
  7. LG VX8700 Ear Piece Replacement, Ear Piece: 7 단계, 이미지 1개 중 1개
    • Locate the earpiece, which is the black component at the top with black and red wires.
    • Remove the component. Using a soldering iron, desolder the top ear piece.
    댓글 쓰기
  8. LG VX8700 Ear Piece Replacement: 8 단계, 이미지 2개 중 1개 LG VX8700 Ear Piece Replacement: 8 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, lift the earpiece to remove it from the phone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
8다른 기여자 명과 함께
Stanley Thomas
회원 가입일: 01/20/12
41 평판
안내서 4개를 작성함
Cal Poly, Team 8-16, Maness Winter 2012 Cal Poly, Team 8-16, Maness Winter 2012 회원
CPSU-MANESS-W12S8G16
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 32
전체 시간: 1,354
