주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Voyager Keyboard Replacement
필요한 것
  1. LG Voyager Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn over the phone so the front screen is facing down and the back side is up.
    댓글 쓰기
  2. LG Voyager Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
    댓글 쓰기
  3. LG Voyager Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
    • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
    • Then press down on the bottom of the battery and it should snap into place
    댓글 쓰기
  4. LG Voyager Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 LG Voyager Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • First remove the rubber stoppers covering the screws on the back of the phone by prying them up and away from the phone.
    댓글 쓰기
  5. LG Voyager Keyboard Replacement: 5 단계, 이미지 2개 중 1개 LG Voyager Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the 3.61mm length, Phillips screws from the back of the phone using the #00 screwdriver.
    댓글 쓰기
  6. LG Voyager Keyboard Replacement: 6 단계, 이미지 2개 중 1개 LG Voyager Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Now pry open the back of the phone.
    • Make sure that you use the plastic opening tool to go around the entire phone to help open the phone.
    댓글 쓰기
  7. LG Voyager Keyboard Replacement: 7 단계, 이미지 2개 중 1개 LG Voyager Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully separate the keyboard from the top of the phone.
    • Be careful not to break the ribbon cable.
    댓글 쓰기
  8. LG Voyager Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Detach the keyboard from the phone by taking off the little metal latches.
    • When replacing the old keyboard with a new one you will have to solder the metal latches to the new board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Lance Collins
회원 가입일: 04/12/12
7 평판
안내서 1개를 작성함
Cal Poly, Team 17-26, Amido Spring 2012 Cal Poly, Team 17-26, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G26
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 690
