주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Laser Lens Cleaning
필요한 것
    1. Laser Lens Cleaning, Top Panel: 1 단계, 이미지 2개 중 1개 Laser Lens Cleaning, Top Panel: 1 단계, 이미지 2개 중 2개
      • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
      • Remove five 7.5 mm Phillips screws on the back of the player.
      댓글 쓰기
    2. Laser Lens Cleaning: 2 단계, 이미지 2개 중 1개 Laser Lens Cleaning: 2 단계, 이미지 2개 중 2개
      • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
      댓글 쓰기
    1. Laser Lens Cleaning, Laser Lens Cleaning: 3 단계, 이미지 2개 중 1개 Laser Lens Cleaning, Laser Lens Cleaning: 3 단계, 이미지 2개 중 2개
      • Locate the lens on the disc drive.
      • Make sure that there is no dust on or near the player and area you are working on. Dust can get on the lens and scratch it while you are cleaning. It is very important that the lens is not damaged because the lens is used to read the discs.
      • Dip one end of a cotton swab in rubbing alcohol.
      • Lightly dab the swab on the lens. Be very gentle.
      • Let the lens dry before replacing the top plate of the DVD player.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nathan Klammer
회원 가입일: 10/06/11
521 평판
안내서 3개를 작성함
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011 회원
CPSU-MANESS-F11S21G20
4 회원들
안내서 24개를 작성함
5가이드 댓글
This item was not appropriate, thank you for trying.
bigd734 - 답글 공유
Works on Samsung's box(home theater), thank you!
CarlBraun - 답글 공유
It worked on my cheap player. This unit is on 24/7. The dust in the house is heavy and smokers so the fix is cheap and I picked up a few things. Thanks
Seeker - 답글 공유
ne fonctionne toujours pas
JEAN PIERRE LARVOR - 답글 공유
My problem I think is alignment
James Smith - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 23
지난 7일: 143
지난 30일: 692
전체 시간: 62,434
