주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Le Pan S Camera Replacement
필요한 것
    1. Le Pan S Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
      • This cover is adjacent to the volume button on the side of the Le Pan S.
      댓글 쓰기
    2. Le Pan S Camera Replacement: 2 단계, 이미지 2개 중 1개 Le Pan S Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Insert the spudger between the front and back panel in order to pry them apart.
      • Do this beside the volume button and the micro SD cover.
      • Pry open the rest of the Le Pan S by dragging the spudger across the side.
      댓글 쓰기
    3. Le Pan S Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
      댓글 쓰기
    4. Le Pan S Camera Replacement: 4 단계, 이미지 2개 중 1개 Le Pan S Camera Replacement: 4 단계, 이미지 2개 중 2개
      • Disconnect the battery from the circuitry and lay it out of the way.
      • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
      • If you are replacing your battery, make sure to dispose of it properly.
      댓글 쓰기
    1. Le Pan S Camera Replacement, Camera: 5 단계, 이미지 1개 중 1개
      • Remove the four 3.5 mm Phillips #00 screws from the circuit board near the bottom of the tablet.
      댓글 쓰기
    2. Le Pan S Camera Replacement: 6 단계, 이미지 1개 중 1개
      • Lift and pull the volume rocker up so it is out of the way of the camera.
      댓글 쓰기
    3. Le Pan S Camera Replacement: 7 단계, 이미지 2개 중 1개 Le Pan S Camera Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the zero insertion force connector (ZIF) by using a plastic opening tool, spudger, or fingernail to lift retaining flap.
      댓글 쓰기
    4. Le Pan S Camera Replacement: 8 단계, 이미지 2개 중 1개 Le Pan S Camera Replacement: 8 단계, 이미지 2개 중 2개
      • Slightly lift up the green electrical board and pull out the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Tyler Ziliak
회원 가입일: 09/17/15
110 평판
안내서 1개를 작성함
IUPUI, Team 2-1, Harley Fall 2015 IUPUI, Team 2-1, Harley Fall 2015 회원
IUPUI-HARLEY-F15S2G1
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 16
전체 시간: 498
