주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LeapFrog LeapPad 2 Screen Assembly Replacement
필요한 것
    1. LeapFrog LeapPad 2 Screen Assembly Replacement, Battery: 1 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Turn the tablet so the back is visible.
      • One at a time, remove the battery covers by sliding them towards the sides and away from the center of the device.
      댓글 쓰기
    2. LeapFrog LeapPad 2 Screen Assembly Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the AA batteries from both battery compartments of the device.
      댓글 쓰기
    1. LeapFrog LeapPad 2 Screen Assembly Replacement, Rear Cover: 3 단계, 이미지 3개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement, Rear Cover: 3 단계, 이미지 3개 중 2개 LeapFrog LeapPad 2 Screen Assembly Replacement, Rear Cover: 3 단계, 이미지 3개 중 3개
      • Use a Phillips #1 screwdriver to remove the following screws from the device:
      • Four 7.0mm Phillips screws
      • Three 6.0mm Phillips screws
      • Two 10.0mm Phillips screws
      • These two screws are behind the barcode decal on the bottom of the device. Expose the screws by puncturing, cutting, or peeling the barcode decal.
      댓글 쓰기
    2. LeapFrog LeapPad 2 Screen Assembly Replacement: 4 단계, 이미지 3개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement: 4 단계, 이미지 3개 중 2개 LeapFrog LeapPad 2 Screen Assembly Replacement: 4 단계, 이미지 3개 중 3개
      • Use a small plastic opening tool to begin separating the colored front cover from the white rear cover of the device.
      • With one hand on the front cover and one hand on the rear cover, start from the bottom of the device and begin pulling the pieces apart.
      • The most stubborn tabs holding the front and rear together are along the top edge of the tablet around the game cartridge slot. This will most likely be the last area that separates, and it may require a moderate amount of force.
      • Once only the top edge remains connected, simultaneously pull the rear cover backwards away from the front cover and upwards towards the top of the device. This should release the last remaining tabs holding the pieces together.
      댓글 쓰기
    1. LeapFrog LeapPad 2 Screen Assembly Replacement, Front Cover: 5 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement, Front Cover: 5 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove two 5.5mm screws from the plastic speaker holder.
      • The rear camera is shown removed in these images, but its removal is optional for most tasks.
      댓글 쓰기
    2. LeapFrog LeapPad 2 Screen Assembly Replacement: 6 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the plastic speaker holder from the device.
      댓글 쓰기
    3. LeapFrog LeapPad 2 Screen Assembly Replacement: 7 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement: 7 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the following screws:
      • One 5.5mm Phillips screw holding the screen assembly.
      • Two 8.0mm Phillips screws holding the motherboard.
      • Two 6.0mm Phillips screws holding the game cartridge slot.
      • One of these screws also holds a black plastic bracket for the front camera, and the bracket is loose once the screw is removed. Set the bracket aside if it falls out.
      • Remember to replace the bracket during this step of reassembly if it was removed.
      • Three 6.0mm Phillips screws holding the auxiliary board.
      • Be careful not to damage the gray ribbon cable connecting the auxiliary board when removing these three screws.
      댓글 쓰기
    4. LeapFrog LeapPad 2 Screen Assembly Replacement: 8 단계, 이미지 3개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement: 8 단계, 이미지 3개 중 2개 LeapFrog LeapPad 2 Screen Assembly Replacement: 8 단계, 이미지 3개 중 3개
      • Locate the following:
      • Two positive battery terminals.
      • Two positive battery wire glue-points.
      • This glue may separate from the motherboard while detaching the battery terminals, but this has no significant impact on the device.
      • Gluing any separated wires back to the motherboard is an optional reassembly step.
      • One terminal at a time, insert a narrow metal spudger through the metal loop of each terminal from the side and pry upwards away from the front cover to release the terminal from the cover.
      • A metal spudger is used because it requires significant force to release the positive battery terminals.
      댓글 쓰기
    5. LeapFrog LeapPad 2 Screen Assembly Replacement: 9 단계, 이미지 3개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement: 9 단계, 이미지 3개 중 2개 LeapFrog LeapPad 2 Screen Assembly Replacement: 9 단계, 이미지 3개 중 3개
      • Two negative battery terminals.
      • Two negative battery wire glue-points.
      • One terminal at a time, pinch the battery side of the terminal towards the wire side of the terminal with a finger or thumb, and pull upwards away from the front cover to release the terminal from the cover.
      • The negative battery terminals require much less force to remove than the positive battery terminals.
      댓글 쓰기
    6. LeapFrog LeapPad 2 Screen Assembly Replacement: 10 단계, 이미지 3개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement: 10 단계, 이미지 3개 중 2개 LeapFrog LeapPad 2 Screen Assembly Replacement: 10 단계, 이미지 3개 중 3개
      • Use the small plastic opening tool to gently lift under the side microphone's black wire to remove the microphone from its slot.
      댓글 쓰기
    7. LeapFrog LeapPad 2 Screen Assembly Replacement: 11 단계, 이미지 1개 중 1개
      • Holding the front cover with one hand and the sides of the motherboard with the other, lift the motherboard away from the front cover.
      • The following may become loose and fall out of position. Reposition them if necessary.
      • Front camera lens.
      • Buttons.
      댓글 쓰기
    8. LeapFrog LeapPad 2 Screen Assembly Replacement: 12 단계, 이미지 3개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement: 12 단계, 이미지 3개 중 2개 LeapFrog LeapPad 2 Screen Assembly Replacement: 12 단계, 이미지 3개 중 3개
      • If the bracket did not previously fall out after removal of the game cartridge slot screws, remove it now and set it aside for reassembly.
      • Front camera bracket location.
      댓글 쓰기
    9. LeapFrog LeapPad 2 Screen Assembly Replacement: 13 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement: 13 단계, 이미지 2개 중 2개
      • The rubber screen border may separate on its own after removing the front cover from the screen assembly and motherboard. Set it aside if it comes off.
      • Pay attention to the original orientation of the rubber screen border to facilitate reassembly.
      댓글 쓰기
    1. LeapFrog LeapPad 2 Screen Assembly Replacement, Separate Motherboard and Screen Assembly: 14 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement, Separate Motherboard and Screen Assembly: 14 단계, 이미지 2개 중 2개
      • Screen assembly tab locations.
      • Slide the motherboard in the direction of the game cartridge slot until the motherboard is out from under the metal tabs on the screen assembly.
      댓글 쓰기
    2. LeapFrog LeapPad 2 Screen Assembly Replacement: 15 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement: 15 단계, 이미지 2개 중 2개
      • Carefully flip the motherboard over by pivoting away from the screen assembly along the long edge with the microphone and speaker, as shown.
      • The motherboard and screen assembly are still connected by a ribbon cable that can be damaged if stressed severely.
      댓글 쓰기
    1. LeapFrog LeapPad 2 Screen Assembly Replacement, Screen Assembly: 16 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement, Screen Assembly: 16 단계, 이미지 2개 중 2개
      • Peel back the tape on the display ribbon cable connector.
      • The front camera is shown removed in these images, but its removal is optional for most tasks.
      댓글 쓰기
    2. LeapFrog LeapPad 2 Screen Assembly Replacement: 17 단계, 이미지 3개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement: 17 단계, 이미지 3개 중 2개 LeapFrog LeapPad 2 Screen Assembly Replacement: 17 단계, 이미지 3개 중 3개
      • Open the display connector by lifting on the brown latch with a plastic opening tool or a finger until it is in a vertical position.
      • Failing to do this correctly could result in damage to the cable and/or connector.
      • Gently pull on the display ribbon cable and it should easily slide out of the connecter.
      • If the connector is properly open, disconnecting the ribbon cable should require little to no force.
      댓글 쓰기
    3. LeapFrog LeapPad 2 Screen Assembly Replacement: 18 단계, 이미지 3개 중 1개 LeapFrog LeapPad 2 Screen Assembly Replacement: 18 단계, 이미지 3개 중 2개 LeapFrog LeapPad 2 Screen Assembly Replacement: 18 단계, 이미지 3개 중 3개
      • The screen assembly is now separated.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chase Mamatey
회원 가입일: 10/05/16
353 평판
안내서 9개를 작성함
USF Tampa, Team 1-5, Sullivan Fall 2016 USF Tampa, Team 1-5, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S1G5
4 회원들
안내서 18개를 작성함
1가이드 댓글
Fix Leappad 2 not touch screen calibrate
Norma Johnson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 58
전체 시간: 3,385
