주요 콘텐츠로 건너뛰기
LeapFrog LeapPad Ultra XDi Battery Replacement
필요한 것
  1. LeapFrog LeapPad Ultra XDi Battery Replacement, Battery: 1 단계, 이미지 1/2 LeapFrog LeapPad Ultra XDi Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
  2. LeapFrog LeapPad Ultra XDi Battery Replacement: 2 단계, 이미지 1/2 LeapFrog LeapPad Ultra XDi Battery Replacement: 2 단계, 이미지 2/2
    • Remove the two 5.0mm Phillips #0 screws.
  3. LeapFrog LeapPad Ultra XDi Battery Replacement: 3 단계, 이미지 1/3 LeapFrog LeapPad Ultra XDi Battery Replacement: 3 단계, 이미지 2/3 LeapFrog LeapPad Ultra XDi Battery Replacement: 3 단계, 이미지 3/3
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
  4. LeapFrog LeapPad Ultra XDi Battery Replacement: 4 단계, 이미지 1/2 LeapFrog LeapPad Ultra XDi Battery Replacement: 4 단계, 이미지 2/2
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
  5. LeapFrog LeapPad Ultra XDi Battery Replacement: 5 단계, 이미지 1/2 LeapFrog LeapPad Ultra XDi Battery Replacement: 5 단계, 이미지 2/2
    • Remove the purple case, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra XDi Battery Replacement: 6 단계, 이미지 1/3 LeapFrog LeapPad Ultra XDi Battery Replacement: 6 단계, 이미지 2/3 LeapFrog LeapPad Ultra XDi Battery Replacement: 6 단계, 이미지 3/3
    • Use the Spudger to remove the glued down battery.
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Replace the battery with a new one.
결론
Victoria Shew
회원 가입일: 08/28/19
503 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 15
전체 시간: 1,154
