주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LeapFrog LeapPad2 Explorer Back Camera Replacement
필요한 것
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Before disassembling your LeapPad, ensure your device is shut off.
      • Push outward on the plastic side panels to remove and reveal battery.
      • The panels should detach fully from the main device.
      댓글 쓰기
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: 2 단계, 이미지 3개 중 1개 LeapFrog LeapPad2 Explorer Back Camera Replacement: 2 단계, 이미지 3개 중 2개 LeapFrog LeapPad2 Explorer Back Camera Replacement: 2 단계, 이미지 3개 중 3개
      • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
      • Remove all four AA alkaline batteries from the device.
      댓글 쓰기
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: 3 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: 3 단계, 이미지 2개 중 2개
      • This step will void your device warranty.
      • Remove the following screws securing the back cover to the main device:
      • Two 10.0 mm Phillips screws
      • Four 4.0 mm Phillips screws
      • Three 3.0 mm Phillips screws
      댓글 쓰기
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: 4 단계, 이미지 3개 중 1개 LeapFrog LeapPad2 Explorer Back Camera Replacement: 4 단계, 이미지 3개 중 2개 LeapFrog LeapPad2 Explorer Back Camera Replacement: 4 단계, 이미지 3개 중 3개
      • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
      • Move the plastic opening tool around the perimeter of the LeapPad2.
      • Lift up and remove the rear case from the tablet.
      • A butter knife can help when prying the device.
      댓글 쓰기
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: 5 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: 5 단계, 이미지 2개 중 2개
      • Locate the back camera below the game cartridge.
      댓글 쓰기
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: 6 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Back Camera Replacement: 6 단계, 이미지 2개 중 2개
      • To safely remove the ribbon cable, first you must pull up the retaining flap.
      • Removing or reinserting the cable by brute force can damage it.
      댓글 쓰기
    3. LeapFrog LeapPad2 Explorer Back Camera Replacement: 7 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Back Camera Replacement: 7 단계, 이미지 2개 중 2개
      • Pull up using a thin plastic tool to disconnect the ribbon connecting the camera to the motherboard.
      댓글 쓰기
    4. LeapFrog LeapPad2 Explorer Back Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Gently remove the back camera from your motherboard by pushing the black casing away from the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Nupur Garg
회원 가입일: 04/12/14
867 평판
안내서 7개를 작성함
Cal Poly, Team 8-10, Regan Spring 2014 Cal Poly, Team 8-10, Regan Spring 2014 회원
CPSU-REGAN-S14S8G10
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 28
전체 시간: 1,534
