주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Leapfrog LeapPad 3 Front Facing Camera Replacement
필요한 것
    1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Front Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Anti-Static Wrist Strap
      $7.95
      • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
      • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
      • You will not need to pry the case off.
      댓글 쓰기
    2. Leapfrog LeapPad 3 Front Facing Camera Replacement: 2 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 2 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 2 단계, 이미지 3개 중 3개
      • Unplug the battery from the motherboard with your hands.
      • The battery sits to the right of the motherboard.
      댓글 쓰기
    3. Leapfrog LeapPad 3 Front Facing Camera Replacement: 3 단계, 이미지 2개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 3 단계, 이미지 2개 중 2개
      • Pry the battery gently off of the plastic platform with an opening tool.
      • Do not to puncture the battery, as the material inside can be dangerous.
      댓글 쓰기
    1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Speaker: 4 단계, 이미지 2개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement, Speaker: 4 단계, 이미지 2개 중 2개
      • Disconnect the audio cord from the motherboard using a plastic opening tool.
      • When re-plugging this cord be sure it is flush with the slot, otherwise the speaker and directional pad will malfunction.
      • Use caution when unplugging, and re-plugging the ribbon cord as they are fragile.
      댓글 쓰기
    2. Leapfrog LeapPad 3 Front Facing Camera Replacement: 5 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 5 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 5 단계, 이미지 3개 중 3개
      • Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
      댓글 쓰기
    3. Leapfrog LeapPad 3 Front Facing Camera Replacement: 6 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 6 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 6 단계, 이미지 3개 중 3개
      • Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
      • Remove the board and speaker from the device.
      댓글 쓰기
    1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
      • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
      댓글 쓰기
    2. Leapfrog LeapPad 3 Front Facing Camera Replacement: 8 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 8 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
      댓글 쓰기
    3. Leapfrog LeapPad 3 Front Facing Camera Replacement: 9 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 9 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 9 단계, 이미지 3개 중 3개
      • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
      • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
      • The device was rotated 180 degrees in order to unplug the display assembly cord.
      댓글 쓰기
    1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Front Facing Camera: 10 단계, 이미지 2개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement, Front Facing Camera: 10 단계, 이미지 2개 중 2개
      • Unscrew the eight 6.5 mm phillips screws from the plastic casing.
      댓글 쓰기
    2. Leapfrog LeapPad 3 Front Facing Camera Replacement: 11 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 11 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 11 단계, 이미지 3개 중 3개
      • Remove the covering with your hand to expose the front facing camera.
      댓글 쓰기
    3. Leapfrog LeapPad 3 Front Facing Camera Replacement: 12 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 12 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Front Facing Camera Replacement: 12 단계, 이미지 3개 중 3개
      • Remove the front facing camera from the outer case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Matt Irvine
회원 가입일: 02/04/16
952 평판
안내서 6개를 작성함
USF Tampa, Team 16-2, Blackwell Winter 2016 USF Tampa, Team 16-2, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G2
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 30
전체 시간: 577
