주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide
필요한 것
    1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Battery: 1 단계, 이미지 1개 중 1개
      • Flip over device so that back portion of the device is facing you.
      댓글 쓰기
    2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 2 단계, 이미지 1개 중 1개
      • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
      • Please note that the screw cannot be removed as it is attached to the battery cover.
      댓글 쓰기
    3. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 3 단계, 이미지 2개 중 1개 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 3 단계, 이미지 2개 중 2개
      • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
      • Remove the three AA batteries.
      • Note the direction of the batteries for when reassembling.
      댓글 쓰기
    1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Keyboard Buttons: 4 단계, 이미지 1개 중 1개
      • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
      댓글 쓰기
    2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 5 단계, 이미지 1개 중 1개
      • Carefully remove back of the device.
      • Make sure not to rip the wires when lifting the cover off.
      댓글 쓰기
    3. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 6 단계, 이미지 2개 중 1개 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 6 단계, 이미지 2개 중 2개
      • Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
      • Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
      댓글 쓰기
    4. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 7 단계, 이미지 1개 중 1개
      • Remove the white plastic piece and place it to the side.
      댓글 쓰기
    5. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 8 단계, 이미지 3개 중 1개 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 8 단계, 이미지 3개 중 2개 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 8 단계, 이미지 3개 중 3개
      • Gently grab the membrane and peel it upwards.
      • Carefully remove the membrane and set it to the side.
      • From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
      • Ensure that the membrane is completely dry before reassembly.
      댓글 쓰기
    6. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 9 단계, 이미지 2개 중 1개 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 9 단계, 이미지 2개 중 2개
      • Gently lift and remove the foam piece
      댓글 쓰기
    7. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 10 단계, 이미지 3개 중 1개 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 10 단계, 이미지 3개 중 2개 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 10 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • From here, each button is able to be removed for cleaning or replacement.
      • Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jonathan Fitzer
회원 가입일: 02/10/16
629 평판
안내서 3개를 작성함
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016 회원
USFT-LACY-S16S14G6
4 회원들
안내서 6개를 작성함
7가이드 댓글
Very useful. but where to get a new membrane? please help
Alina Timchenko - 답글 공유
Didn't work. I'll buy a new toy.
victoria_nglover19 - 답글 공유
Is the screen on this suppose to light up?
stewartmelinda41 - 답글 공유
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
Njabulo Mbele - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 97
전체 시간: 6,515
