주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Led Lenser P2 BM Button Disassembly
필요한 것
    1. Led Lenser  P2 BM  Button Disassembly, Unscrew rear cap from the main housing: 1 단계, 이미지 1개 중 1개
      • This is exactly how you would do it if you were changing the battery.
      댓글 쓰기
    2. Led Lenser  P2 BM  Button Disassembly, Remove O-ring: 2 단계, 이미지 1개 중 1개
      • Remove the small O-Ring, I used a plastic toothpick.
      댓글 쓰기
    3. Led Lenser  P2 BM  Button Disassembly, Screw apart cap: 3 단계, 이미지 2개 중 1개 Led Lenser  P2 BM  Button Disassembly, Screw apart cap: 3 단계, 이미지 2개 중 2개
      • Now we will unscrew the aluminum cap from the plastic lower part. I used a pair of pliers to carefully hold the plastic part while unscrewing the aluminum part with my finger. Left-hand thread.
      댓글 쓰기
    4. Led Lenser  P2 BM  Button Disassembly, Split housing: 4 단계, 이미지 1개 중 1개
      • The plastic housing holds the actual button assembly and is made from two halves, These can carefully be pried apart wit a knife.
      댓글 쓰기
    5. Led Lenser  P2 BM  Button Disassembly, Open button assembly: 5 단계, 이미지 2개 중 1개 Led Lenser  P2 BM  Button Disassembly, Open button assembly: 5 단계, 이미지 2개 중 2개
      • Button assembly mark in red circle. This is held together by 4 plastic "rivets" on the connector side, marked in green. Cafully cut these flush like in the picture.
      댓글 쓰기
    6. Led Lenser  P2 BM  Button Disassembly, Separate the button. Clean and ispect: 6 단계, 이미지 2개 중 1개 Led Lenser  P2 BM  Button Disassembly, Separate the button. Clean and ispect: 6 단계, 이미지 2개 중 2개
      • You can then pry of the "lid" like in the third picture.
      • Carefully remove the inner springs and plungers. In the picture one small plunger is still in the top of the button.
      • In my case the problem was a tiny plastic "!shaving" inside the button blocking it from making a connection, Market with yellow arrow.
      댓글 쓰기
    7. Led Lenser  P2 BM  Button Disassembly, Reassemble: 7 단계, 이미지 1개 중 1개
      • Is reversed of disassembly but you don't need to glue the button together (the small plastic "rivets" are now broken) because the two part plastic housing will keep it together when assembled.
      • I have used it like this for years until the same problem happen again, so added some new images while fixing it again.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Hans
회원 가입일: 04/25/16
430 평판
안내서 2개를 작성함
3가이드 댓글
Dear Hans.
I have used the same P3 LED for many years in bad switch condition.
Today I cleared this problem with your solution.
Very thank you & I'm appreciate to you.
DS2DDE
from Seoul, Korea.
김도욱 - 답글 공유
can you show how to take the front part apart?
Eric Secreve - 답글 공유
@ericsecreve Sadly I lost the light on an exercise, it's somewhere out in the woods now, all alone, cold and wet.
Hans - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 24
지난 30일: 119
전체 시간: 4,802
