주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lefant M210 Battery Replacement
필요한 것
  1. Lefant M210 Battery Replacement, Brush: 1 단계, 이미지 2개 중 1개 Lefant M210 Battery Replacement, Brush: 1 단계, 이미지 2개 중 2개
    • Turn off the Lefant M210 and disconnect it from the charging dock.
    • Flip the unit over so the bottom faces upward.
    • Locate the circular brush assemblies on the left and right sides of the underside.
    • Place the unit on a clean, flat surface to prevent scratching.
    댓글 쓰기
  2. Lefant M210 Battery Replacement: 2 단계, 이미지 3개 중 1개 Lefant M210 Battery Replacement: 2 단계, 이미지 3개 중 2개 Lefant M210 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
    • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
    • Remove the brush assembly completely and set it aside.
    • If replacing both brush assemblies, repeat this process on the other side.
    • Avoid using excessive force, which may damage the mounting clips.
    댓글 쓰기
    • Position the new brush assembly above the square mounting peg.
    • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
    • Press down firmly on the brush assembly until you hear or feel it click into place.
    • Gently tug on the brush to verify it is securely seated.
    • The brush should sit flush with the housing and not move when pulled gently.
    댓글 쓰기
  3. Lefant M210 Battery Replacement, Wheel Assembly: 4 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove four screws near each wheel.
    댓글 쓰기
  4. Lefant M210 Battery Replacement: 5 단계, 이미지 2개 중 1개 Lefant M210 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the plastic cover next to each wheel.
    • Grip both sides of the wheel and pull upwards.
    • The wheels of the device require some force to remove.
    • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
    댓글 쓰기
  5. Lefant M210 Battery Replacement: 6 단계, 이미지 3개 중 1개 Lefant M210 Battery Replacement: 6 단계, 이미지 3개 중 2개 Lefant M210 Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Hold the wheel up and detach the connector to release it from the device.
    댓글 쓰기
  6. Lefant M210 Battery Replacement, Dustbin Filters: 7 단계, 이미지 1개 중 1개
    • Open the dustbin compartment.
    댓글 쓰기
  7. Lefant M210 Battery Replacement: 8 단계, 이미지 2개 중 1개 Lefant M210 Battery Replacement: 8 단계, 이미지 2개 중 2개
    • With your hands, gently pull the dustbin to remove it from its compartment.
    댓글 쓰기
  8. Lefant M210 Battery Replacement: 9 단계, 이미지 1개 중 1개
    • With your hands, pull off the filter compartment from the dustbin.
    댓글 쓰기
  9. Lefant M210 Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Pull off the filter from the filter compartment.
    댓글 쓰기
  10. Lefant M210 Battery Replacement, Battery: 11 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the six screws around the bottom edge of the device.
    댓글 쓰기
  11. Lefant M210 Battery Replacement: 12 단계, 이미지 2개 중 1개 Lefant M210 Battery Replacement: 12 단계, 이미지 2개 중 2개
    • Carefully flip the vacuum back right-side-up, making sure you're holding it all together so that the bottom portion doesn't fall out.
    • Rotate the vacuum so that the Lefant logo is facing you.
    • Carefully lift the white cover of the vacuum, opening it like a laptop, from front to back.
    • Rest the open cover something stable, like a wall.
    댓글 쓰기
  12. Lefant M210 Battery Replacement: 13 단계, 이미지 2개 중 1개 Lefant M210 Battery Replacement: 13 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the three screws securing the motherboard to the device.
    댓글 쓰기
  13. Lefant M210 Battery Replacement: 14 단계, 이미지 1개 중 1개
    • Carefully lift the motherboard, ensuring you don't rip any cables that are connected to it.
    • The battery should be under the motherboard.
    댓글 쓰기
  14. Lefant M210 Battery Replacement: 15 단계, 이미지 2개 중 1개 Lefant M210 Battery Replacement: 15 단계, 이미지 2개 중 2개
    • Push the two retaining clips away from the battery while pulling the battery up from the tabs attached to it to free it.
    • Retaining clips
    • Battery tabs
    • Work on freeing one side at a time so that it's easier to free the battery.
    댓글 쓰기
  15. Lefant M210 Battery Replacement: 16 단계, 이미지 1개 중 1개
    • When the battery is free from it's housing, lift it out completely using its pull tabs.
    댓글 쓰기
  16. Lefant M210 Battery Replacement: 17 단계, 이미지 2개 중 1개 Lefant M210 Battery Replacement: 17 단계, 이미지 2개 중 2개
    • Locate the battery connection wire and carefully pull apart the connection.
    • Pinch the motherboard's wire connector and pull the connection apart.
    • The connection is secured by a clothespin-like mechanism.
    • When you replace your battery with a new one, allow the robot vacuum to fully charge for a few hours before using it again.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Darien Amador
회원 가입일: 09/09/24
300 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-4, Kershman Fall 2024 CSU Los Angeles, Team 2-4, Kershman Fall 2024 회원
CSULA-KERSHMAN-F24S2G4
4 회원들
안내서 13개를 작성함
5가이드 댓글
Great guide! Any knowledge on how or why mine beeps twice even when it is on the ground?
Jonathan Manuel - 답글 공유
Thank you for the helpful guide, however, after replacing my battery, it definitely has a much shorter lifespan, and it is unable to find the charger before it dies.
Tee Cee - 답글 공유
I thought it was because I needed a new battery. My stops about 1min after start. When I put it back to the charger it indicates battery charged by showing the blue light. Still after 1 min of operation it dies. That's the reason why i want to replace the battery. Is that what yours is doing too even after replacing the battery?
Zed - 답글 공유
Thanks for the guide.
As for those that stumble upon this, mind that ******if you only want to access the battery, steps 10 to 16 are the only on you need.
Sylvain “Neoblasphem” Mourot - 답글 공유
Bought new batt, installed it and same problem. Red light, not charging. I guess it’s dead for good.
Kelly In Cali - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 30
지난 7일: 217
지난 30일: 983
전체 시간: 15,104
