주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lefant M210 Brush Replacement
필요한 것
    1. Lefant M210 Brush Replacement, Brush: 1 단계, 이미지 2개 중 1개 Lefant M210 Brush Replacement, Brush: 1 단계, 이미지 2개 중 2개
      • Turn off the Lefant M210 and disconnect it from the charging dock.
      • Flip the unit over so the bottom faces upward.
      • Locate the circular brush assemblies on the left and right sides of the underside.
      • Place the unit on a clean, flat surface to prevent scratching.
      댓글 쓰기
    2. Lefant M210 Brush Replacement: 2 단계, 이미지 3개 중 1개 Lefant M210 Brush Replacement: 2 단계, 이미지 3개 중 2개 Lefant M210 Brush Replacement: 2 단계, 이미지 3개 중 3개
      • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
      • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
      • Remove the brush assembly completely and set it aside.
      • If replacing both brush assemblies, repeat this process on the other side.
      • Avoid using excessive force, which may damage the mounting clips.
      댓글 쓰기
      • Position the new brush assembly above the square mounting peg.
      • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
      • Press down firmly on the brush assembly until you hear or feel it click into place.
      • Gently tug on the brush to verify it is securely seated.
      • The brush should sit flush with the housing and not move when pulled gently.
      댓글 쓰기
결론
If problems occur: Power off the unit, flip it over, and verify the brush is correctly aligned and fully seated. With fresh brushes installed, your robot vacuum is back in action and ready to keep your floors spotless!
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Brittany I
회원 가입일: 09/09/24
173 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-4, Kershman Fall 2024 CSU Los Angeles, Team 2-4, Kershman Fall 2024 회원
CSULA-KERSHMAN-F24S2G4
4 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 76
전체 시간: 513
