주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lefant M210 Wheel Assembly Replacement
필요한 것
    1. Lefant M210 Wheel Assembly Replacement, Brush: 1 단계, 이미지 2개 중 1개 Lefant M210 Wheel Assembly Replacement, Brush: 1 단계, 이미지 2개 중 2개
      • Turn off the Lefant M210 and disconnect it from the charging dock.
      • Flip the unit over so the bottom faces upward.
      • Locate the circular brush assemblies on the left and right sides of the underside.
      • Place the unit on a clean, flat surface to prevent scratching.
      댓글 쓰기
    2. Lefant M210 Wheel Assembly Replacement: 2 단계, 이미지 3개 중 1개 Lefant M210 Wheel Assembly Replacement: 2 단계, 이미지 3개 중 2개 Lefant M210 Wheel Assembly Replacement: 2 단계, 이미지 3개 중 3개
      • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
      • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
      • Remove the brush assembly completely and set it aside.
      • If replacing both brush assemblies, repeat this process on the other side.
      • Avoid using excessive force, which may damage the mounting clips.
      댓글 쓰기
      • Position the new brush assembly above the square mounting peg.
      • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
      • Press down firmly on the brush assembly until you hear or feel it click into place.
      • Gently tug on the brush to verify it is securely seated.
      • The brush should sit flush with the housing and not move when pulled gently.
      댓글 쓰기
    1. Lefant M210 Wheel Assembly Replacement, Wheel Assembly: 4 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove four screws near each wheel.
      댓글 쓰기
    2. Lefant M210 Wheel Assembly Replacement: 5 단계, 이미지 2개 중 1개 Lefant M210 Wheel Assembly Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the plastic cover next to each wheel.
      • Grip both sides of the wheel and pull upwards.
      • The wheels of the device require some force to remove.
      • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
      댓글 쓰기
    3. Lefant M210 Wheel Assembly Replacement: 6 단계, 이미지 3개 중 1개 Lefant M210 Wheel Assembly Replacement: 6 단계, 이미지 3개 중 2개 Lefant M210 Wheel Assembly Replacement: 6 단계, 이미지 3개 중 3개
      • Hold the wheel up and detach the connector to release it from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Adrian pg
회원 가입일: 09/09/24
147 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-4, Kershman Fall 2024 CSU Los Angeles, Team 2-4, Kershman Fall 2024 회원
CSULA-KERSHMAN-F24S2G4
4 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 141
전체 시간: 2,076
