주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Left Joy-Con Charging Rail Replacement
필요한 것
    1. Left Joy-Con Charging Rail Replacement, Charging Rail: 1 단계, 이미지 2개 중 1개 Left Joy-Con Charging Rail Replacement, Charging Rail: 1 단계, 이미지 2개 중 2개
      • Use the Tri-point Y00 screwdriver to remove the four 6 mm screws from the back of the Joy-Con.
      댓글 쓰기
    2. Left Joy-Con Charging Rail Replacement: 2 단계, 이미지 3개 중 1개 Left Joy-Con Charging Rail Replacement: 2 단계, 이미지 3개 중 2개 Left Joy-Con Charging Rail Replacement: 2 단계, 이미지 3개 중 3개
      • Insert the opening pick into the bottom of the Joy-Con, then move it towards the L and ZL buttons.
      • Lift the back shell off the Joy-Con and place it to the side.
      • Be careful when removing the back shell as it is connected to two ribbon cables by the charging rail and motherboard. Potential for device damage may occur if it is yanked apart.
      댓글 쓰기
    3. Left Joy-Con Charging Rail Replacement: 3 단계, 이미지 3개 중 1개 Left Joy-Con Charging Rail Replacement: 3 단계, 이미지 3개 중 2개 Left Joy-Con Charging Rail Replacement: 3 단계, 이미지 3개 중 3개
      • Insert a spudger or prying tool beneath the battery wires and gently pry the battery plug out of the socket on the motherboard.
      • Once the battery plug is removed from the socket, lift the battery off the mid-frame.
      • A spudger is recommended for this step if one is available. If not, use an ESD safe tool.
      댓글 쓰기
    4. Left Joy-Con Charging Rail Replacement: 4 단계, 이미지 3개 중 1개 Left Joy-Con Charging Rail Replacement: 4 단계, 이미지 3개 중 2개 Left Joy-Con Charging Rail Replacement: 4 단계, 이미지 3개 중 3개
      • Unscrew the three golden 3 mm Phillips #000 screws holding the mid-frame in place.
      • Lift the mid-frame off the motherboard and place it to the side.
      댓글 쓰기
    5. Left Joy-Con Charging Rail Replacement: 5 단계, 이미지 3개 중 1개 Left Joy-Con Charging Rail Replacement: 5 단계, 이미지 3개 중 2개 Left Joy-Con Charging Rail Replacement: 5 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Unlatch the ZIF connector that is locking the ribbon cable on the mid-frame to the motherboard.
      • Use tweezers to gently pull the ribbon cable out of the ZIF connector.
      댓글 쓰기
    6. Left Joy-Con Charging Rail Replacement: 6 단계, 이미지 3개 중 1개 Left Joy-Con Charging Rail Replacement: 6 단계, 이미지 3개 중 2개 Left Joy-Con Charging Rail Replacement: 6 단계, 이미지 3개 중 3개
      • Unlatch the two ZIF connectors that are locking the ribbon cables on the charging rail to the motherboard.
      • Use tweezers to gently pull the ribbon cables out of the ZIF connectors.
      댓글 쓰기
    7. Left Joy-Con Charging Rail Replacement: 7 단계, 이미지 3개 중 1개 Left Joy-Con Charging Rail Replacement: 7 단계, 이미지 3개 중 2개 Left Joy-Con Charging Rail Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the 2 mm Philips #000 screw holding the charging rail onto the back shell.
      • Remove the charging rail from the back shell.
      • There is an adhesive tape that helps keep the charging rail in place on the back shell. When placing the new charging rail onto the back shell, it is advised to also replace the adhesive to add extra support, but it is not essential.
      댓글 쓰기
    8. Left Joy-Con Charging Rail Replacement: 8 단계, 이미지 2개 중 1개 Left Joy-Con Charging Rail Replacement: 8 단계, 이미지 2개 중 2개
      • Use the Phillips #000 screwdriver to remove the two 3 mm screws at the center of the PCB.
      • Remove the PCB from the charging rail.
      댓글 쓰기
    9. Left Joy-Con Charging Rail Replacement: 9 단계, 이미지 3개 중 1개 Left Joy-Con Charging Rail Replacement: 9 단계, 이미지 3개 중 2개 Left Joy-Con Charging Rail Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the SL, SR and sync buttons from the charging rail.
      댓글 쓰기
    10. Left Joy-Con Charging Rail Replacement: 10 단계, 이미지 3개 중 1개 Left Joy-Con Charging Rail Replacement: 10 단계, 이미지 3개 중 2개 Left Joy-Con Charging Rail Replacement: 10 단계, 이미지 3개 중 3개
      • Place the SL, SR and sync buttons into the new charging rail and make sure the tabs on the SL and SR buttons fit into their respective socket grooves.
      • Place the PCB over the buttons and secure it in place using the two golden 3 mm Phillips #000 screws.
      • Potential for device damage. If the buttons are not properly placed into the charging rail, proceeding to screw in the PCB will cause it to warp.
      댓글 쓰기
    11. Left Joy-Con Charging Rail Replacement: 11 단계, 이미지 2개 중 1개 Left Joy-Con Charging Rail Replacement: 11 단계, 이미지 2개 중 2개
      • Align the charging rail with the two standoffs on the back shell.
      • Secure the rail onto the back shell using the 2 mm Phillips #000 screws.
      댓글 쓰기
    12. Left Joy-Con Charging Rail Replacement: 12 단계, 이미지 3개 중 1개 Left Joy-Con Charging Rail Replacement: 12 단계, 이미지 3개 중 2개 Left Joy-Con Charging Rail Replacement: 12 단계, 이미지 3개 중 3개
      • Use tweezers to insert the ribbon cables for the charging rail into the ZIF connectors on the motherboard.
      • Press down on the latch for each ZIF connector to secure the ribbon cables in place.
      댓글 쓰기
    13. Left Joy-Con Charging Rail Replacement: 13 단계, 이미지 2개 중 1개 Left Joy-Con Charging Rail Replacement: 13 단계, 이미지 2개 중 2개
      • Use tweezers to insert the ribbon cable for the mid-frame into the ZIF connector on the motherboard, with the golden pins facing upwards.
      • Press down on the ZIF connector latch to secure the ribbon cable in place.
      댓글 쓰기
    14. Left Joy-Con Charging Rail Replacement: 14 단계, 이미지 2개 중 1개 Left Joy-Con Charging Rail Replacement: 14 단계, 이미지 2개 중 2개
      • Place the the mid-frame over the motherboard.
      • Using Philips #000 screwdriver, secure the three golden 3 mm screws of the mid-frame onto the motherboard.
      • When placing the mid-frame onto the motherboard, the bumper button may come loose. To reattach the bumper button, first insert the spring on the bumper button into the groove located on the top left side of the Joy-Con, then insert the right side of the bumper button into the Joy-Con.
      댓글 쓰기
    15. Left Joy-Con Charging Rail Replacement: 15 단계, 이미지 2개 중 1개 Left Joy-Con Charging Rail Replacement: 15 단계, 이미지 2개 중 2개
      • Place the battery into the mid-frame.
      • Use tweezers to align the battery plug over the socket and with a pry tool or an object with a flat edge, press the plug into the socket.
      댓글 쓰기
    16. Left Joy-Con Charging Rail Replacement: 16 단계, 이미지 3개 중 1개 Left Joy-Con Charging Rail Replacement: 16 단계, 이미지 3개 중 2개 Left Joy-Con Charging Rail Replacement: 16 단계, 이미지 3개 중 3개
      • Align the charging rail into the notch on the left side of the Joy-Con.
      • Apply even pressure on both sides of the Joy-Con until the two shells click together.
      • Screw in the four 6 mm Tri-point Y00 screws into the back of the Joy-Con.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 52명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Peter Lam
회원 가입일: 09/19/20
2,284 평판
안내서 2개를 작성함
York University, Team S1-G14, O'Regan Summer 2021 York University, Team S1-G14, O'Regan Summer 2021 회원
YORK-O'REGAN-SU21S1G14
1 회원
안내서 10개를 작성함
18가이드 댓글
I did this and still doesn’t work. I also changed the rail on the console side too. Very carefully of course. Any ideas?
Luis - 답글 공유
Hey Luis,
Can you give me more detail on the problem? Like is the Joy-Con not being detected when it’s plugged in or is it not charging. If possible, can you test the console rail with a working Joy-Con?
If the Joy-Con is not charging, it could also be a battery problem. If you are comfortable with it, I would suggest swapping out the battery with a working one from the other Joy-Con to see if it solves the problem. You should probably attempt this after double-checking the connections for potential tears or if the connectors are too loose in the sockets.
Peter Lam - 답글 공유
Hi, I need help. My left Joy-Con is not charging because of the ZIF connector for the charging rail ribbon has been detached and I have lost it. Is there a way to fix this problem?
Jakkrij Sihanatkathakul - 답글 공유
Honestly, I would recommend replacing the entire Motherboard, unless you can find a trusted repair shop to solder it on.
I damaged the ZIF connector for the battery on my Switch. It works with some pressure and perfect alignment, but I've had issues ever since I damaged it during repairs :/
I'm going to swap it with a functional motherboard, I would advise you do the same.
Yakarot Sennin - 답글 공유
Hello need a little help. the ribbon cable will not stay connected. and it will not charger. Any thing will help.
Matthew Molt - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 84
지난 7일: 564
지난 30일: 2,238
전체 시간: 134,632
