주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Essential B570 Keyboard Replacement
필요한 것
  1. Lenovo Essential B570 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn over laptop.
    • Switch open the left battery lock.
    • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
    댓글 쓰기
  2. Lenovo Essential B570 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Hold the right battery lock open with one hand while removing the battery itself with the other.
    댓글 쓰기
  3. Lenovo Essential B570 Keyboard Replacement, Back Panel: 3 단계, 이미지 1개 중 1개
    • Loosen the five Philips screws that secure the panel.
    • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
    댓글 쓰기
  4. Lenovo Essential B570 Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Lenovo Essential B570 Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Lenovo Essential B570 Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Prop open the cover with a plastic opening tool.
    • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
    댓글 쓰기
  5. Lenovo Essential B570 Keyboard Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
    • Remove the three 3 mm Phillips screws holding the keyboard in. These screws are designated by an imprinted keyboard picture next to them.
    댓글 쓰기
  6. Lenovo Essential B570 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Lenovo Essential B570 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully pry off the keyboard with your plastic opening tool , moving along the edges.
    • DO NOT immediately remove the keyboard as it is still connected underneath by a wire.
    댓글 쓰기
  7. Lenovo Essential B570 Keyboard Replacement: 7 단계, 이미지 2개 중 1개 Lenovo Essential B570 Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully lift the keyboard.
    • The keyboard is still connected to the laptop. Lift it slowly.
    • Turn over the keyboard to locate the keyboards ribbon cable.
    댓글 쓰기
  8. Lenovo Essential B570 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Lenovo Essential B570 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to lift open the ribbon connector that is holding the ribbon cable in its slot.
    댓글 쓰기
  9. Lenovo Essential B570 Keyboard Replacement: 9 단계, 이미지 2개 중 1개 Lenovo Essential B570 Keyboard Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the cable from its slot.
    • If the cable does not come out easily, ensure that the black ribbon has been completely released.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Samuel Filliettaz
회원 가입일: 10/20/15
900 평판
안내서 5개를 작성함
UMass Dartmouth, Team 4-5, Catania Fall 2015 UMass Dartmouth, Team 4-5, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G5
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 33
전체 시간: 3,129
