주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Essential G560 Optical Drive Replacement
필요한 것
    1. Lenovo Essential G560 Optical Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Turn off the computer.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the cable could result in electric shock.
      • Flip the computer upside down.
      댓글 쓰기
    2. Lenovo Essential G560 Optical Drive Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Essential G560 Optical Drive Replacement: 2 단계, 이미지 2개 중 2개
      • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
      댓글 쓰기
    3. Lenovo Essential G560 Optical Drive Replacement: 3 단계, 이미지 1개 중 1개
      • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
      댓글 쓰기
    1. Lenovo Essential G560 Optical Drive Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
      • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
      댓글 쓰기
    2. Lenovo Essential G560 Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 Lenovo Essential G560 Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
      • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
      • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
      댓글 쓰기
    3. Lenovo Essential G560 Optical Drive Replacement: 6 단계, 이미지 1개 중 1개
      • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
      댓글 쓰기
    1. Lenovo Essential G560 Optical Drive Replacement, Optical Drive: 7 단계, 이미지 2개 중 1개 Lenovo Essential G560 Optical Drive Replacement, Optical Drive: 7 단계, 이미지 2개 중 2개
      • Locate the Optical Drive 4.7 mm Philips #1 screw, which secures the Optical Drive into the body of the laptop.
      댓글 쓰기
    2. Lenovo Essential G560 Optical Drive Replacement: 8 단계, 이미지 1개 중 1개
      • Using the Philips #1 Screwdriver, remove the Optical Drive 4.7 mm Philips #1 screw. Once you remove the screw, locate the metal tab beneath the screw and push it outwards.
      • It may be useful to use the spudger to push the metal tab, as there is not enough space for your finger or plastic opening tool.
      • Be firm, yet gentle to avoid damaging the electronic connections.
      댓글 쓰기
    3. Lenovo Essential G560 Optical Drive Replacement: 9 단계, 이미지 2개 중 1개 Lenovo Essential G560 Optical Drive Replacement: 9 단계, 이미지 2개 중 2개
      • Slide the Optical Drive smoothly out of its slot.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Dennis Wong
회원 가입일: 01/11/13
618 평판
안내서 5개를 작성함
Cal Poly, Team 18-40, Regan Winter 2013 Cal Poly, Team 18-40, Regan Winter 2013 회원
CPSU-REGAN-W13S18G40
5 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 46
전체 시간: 5,893
