주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Essential G570 Keyboard Replacement
필요한 것
  1. Lenovo Essential G570 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
    댓글 쓰기
  2. Lenovo Essential G570 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Essential G570 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
    댓글 쓰기
  3. Lenovo Essential G570 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Lenovo Essential G570 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
    댓글 쓰기
  4. Lenovo Essential G570 Keyboard Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
    • Turn the laptop over so that the bottom side is facing up.
    댓글 쓰기
  5. Lenovo Essential G570 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
    댓글 쓰기
  6. Lenovo Essential G570 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Lenovo Essential G570 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Lenovo Essential G570 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
    댓글 쓰기
  7. Lenovo Essential G570 Keyboard Replacement, Keyboard: 7 단계, 이미지 1개 중 1개
    • Remove the two 9mm Phillips #0 screws.
    • Remove the single 5mm Phillips #0 screw.
    • All 3 screws are located next to keyboard icons.
    댓글 쓰기
  8. Lenovo Essential G570 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Lenovo Essential G570 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Flip the computer over and open it.
    • Using the plastic opening tool, pry open the top of the keyboard.
    댓글 쓰기
  9. Lenovo Essential G570 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the keyboard by gently pulling the top of the keyboard loose, and then lifting the keyboard out.
    • Be careful lifting the keyboard up because there is a delicate ribbon cable connected to the bottom.
    댓글 쓰기
  10. Lenovo Essential G570 Keyboard Replacement: 10 단계, 이미지 3개 중 1개 Lenovo Essential G570 Keyboard Replacement: 10 단계, 이미지 3개 중 2개 Lenovo Essential G570 Keyboard Replacement: 10 단계, 이미지 3개 중 3개
    • While lifting the keyboard, push the black latch on the keyboard cable ZIF connector forward to unlock it.
    • Carefully pull away the ribbon cable to detach it from the motherboard.
    • Be careful when unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nina Francisco
회원 가입일: 03/01/18
412 평판
안내서 2개를 작성함
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 UMass Dartmouth, Team S1-G1, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S1G1
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 42
전체 시간: 3,129
