주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Essential G570 RAM Replacement
필요한 것
  1. Lenovo Essential G570 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
    댓글 쓰기
  2. Lenovo Essential G570 RAM Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Essential G570 RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
    댓글 쓰기
  3. Lenovo Essential G570 RAM Replacement: 3 단계, 이미지 2개 중 1개 Lenovo Essential G570 RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
    댓글 쓰기
  4. Lenovo Essential G570 RAM Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
    • Turn the laptop over so that the bottom side is facing up.
    댓글 쓰기
  5. Lenovo Essential G570 RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
    댓글 쓰기
  6. Lenovo Essential G570 RAM Replacement: 6 단계, 이미지 3개 중 1개 Lenovo Essential G570 RAM Replacement: 6 단계, 이미지 3개 중 2개 Lenovo Essential G570 RAM Replacement: 6 단계, 이미지 3개 중 3개
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
    댓글 쓰기
  7. Lenovo Essential G570 RAM Replacement, RAM: 7 단계, 이미지 1개 중 1개
    • Using your fingers, hold open the two clips holding the top RAM in place.
    • The two RAM chips are placed one on top of another. It is important to take the top one out first to easily access the bottom one.
    • With the clips held away from the RAM, slide the top stick out from it's connection.
    댓글 쓰기
  8. Lenovo Essential G570 RAM Replacement: 8 단계, 이미지 1개 중 1개
    • With the top RAM stick removed, repeat the same process for the bottom piece. Begin by holding the two clips away from the RAM.
    • With the clips held out, slide the RAM out from the connection.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Justin Bickford
회원 가입일: 03/01/18
479 평판
안내서 2개를 작성함
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 UMass Dartmouth, Team S1-G1, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S1G1
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 25
전체 시간: 1,094
