주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 3-15IIL05 Battery Replacement
필요한 것
  1. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 1/2 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2/2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Unfasten the back cover: 2 단계, 이미지 1/2 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Unfasten the back cover: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  3. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Insert an opening pick: 3 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Insert an opening pick: 3 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Insert an opening pick: 3 단계, 이미지 3/3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  4. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the left clips: 4 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the left clips: 4 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the left clips: 4 단계, 이미지 3/3
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  5. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the bottom clips: 5 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the bottom clips: 5 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the bottom clips: 5 단계, 이미지 3/3
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  6. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the right clips: 6 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the right clips: 6 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the right clips: 6 단계, 이미지 3/3
    • Slide the opening pick to the top right corner to release the right clips.
  7. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Insert an opening pick: 7 단계, 이미지 1/2 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Insert an opening pick: 7 단계, 이미지 2/2
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  8. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the top clips: 8 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the top clips: 8 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the top clips: 8 단계, 이미지 3/3
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  9. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Remove the back cover: 9 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Remove the back cover: 9 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Remove the back cover: 9 단계, 이미지 3/3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  10. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Disconnect the battery: 10 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Disconnect the battery: 10 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Disconnect the battery: 10 단계, 이미지 3/3
    • Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
  11. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Unfasten the battery: 11 단계, 이미지 1/2 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Unfasten the battery: 11 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the three 5.7 mm-long screws securing the battery.
  12. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Remove the battery: 12 단계, 이미지 1/2 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Remove the battery: 12 단계, 이미지 2/2
    • Remove the battery.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Check your repair by running hardware tests with Lenovo Diagnostics.
다른 2명이 해당 안내서를 완성하였습니다.
Spencer Day
회원 가입일: 09/14/22
53,280 평판
안내서 389개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,136개 작성하였습니다
댓글 한 개
Great instructions. Tools were perfect.
Stuwas - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 132
30일 전: 568
전체 시간: 2,967
